Hi all,i took the carbs off to see if there was anything floating around that could cause my misfire but they were clean inside. I also wanted to have a look at the inlet manifolds as in one of my previous posts was posted a line drawing showing restrictions in them.
When i removed them, as you can see in the pics the manifold narrows in the middle from 40mm to 25mm, it is part of the inlet and cannot be removed. I have taken a pic of both of them showing the two sides so you can compare them to yours.
I'm fairly sure that this is the restriction and a "full power" unrestricted inlet manifold would just be a straight connecting rubber from carb to engine.
Mine came from Germany and i was told that they are restricted to 50bhp instead of the usual 57.
I've had a look on wemoto's site and they show a straight through "pattern" pair. I was worried if i order a pair from honda they would be the same as the ones ive got.
I'll keep you posted about the difference when i fit the new ones.
