Results 1 to 10 of 19
Thread: aaaaggggggghhhhhhhhhhhhh! I'm a numptie!
    zxtrevr's Avatar
    zxtrevr is offline Bus Driver
    Maghera, Northern Ireland
    Was trying to change a weeping rocker cover gasket on the rear cylinder, took off the coolant pipe on the back of cylinder (in the V) pulled it out and dropped the little bolt, can't find the little bugger anywhere and I think it might have went down the hole into the cooling system, what now????????? obviously just can't leave it in there... :confused
    Lutin's Avatar
    Galway
    Re: aaaaggggggghhhhhhhhhhhhh! I'm a numptie!
    Are you absolutely sure that the bolt went into the engine?
    There are plenty of @ owners on here that have lost bits and found them rattling around in the sump guard / bash plate. Some members are convinced that there is witchcraft involved, such is the amazing part swallowing ability of the bash plate!!
    nomad's Avatar
    nomad is offline chicken chaser
    horwich, bolton, lancs
    agree with lutin
    you can find lost families in your bash plate
    how big is the hole you think it dropped into ??
    is it big enough to get one of those telescoping magnets down ...
    Lutin's Avatar
    Galway
    Quote Originally Posted by nomad View Post
    Or even a magnet on a piece of string.
    Sohoeasy's Avatar
    Sohoeasy is offline Stone Chiller.
    May 2005
    Westminster London
    Pleeeeeeeeeze tell us it's turned out alright
    Here we Go!!!!!!!!!!!!!!!!!
    Wangit's Avatar
    Wangit is offline Tea boy
    Oct 2008
    Mid Wales on the borders
    A few years ago I dropped a 10 mm nut into the cooling system on my car, I had that frozen moment where you just can't believe you are that numptie. I got it out by using an old net curtain over the pipe end, bound on with an elastic band, then I opened the water system at another point, and put the nozzle of a hose pipe into the system and turned on the tap, and hey presto it just popped out into the net bag. I think providing you pick a point that does not have the thermostat in the way it should work. But like the other folks have said, it's probably sitting on some little ledge looking right at you, just waiting for you to strip everything down, I guess a kind of witchcraft, nut gremlin thing.
    futter's Avatar
    Jul 2005
    Suffolk
    If you do this make damn sure you tie a good knot on a decent piece of string!
    I have a good friend (mechanic) who has rebuilt 2 engines as THE SAME twit used wool, yes wool, to tie his magnet too to get parts out of the wrong place whilst performing some piece of mechanical butchery!
    zxtrevr's Avatar
    haven't been bothered to look at it today, still a bit angry with myself. Will keep you up to date..
    tedmagnum's Avatar
    Jul 2005
    liverpool
    Where does the hole go ???
    nomad's Avatar
    Quote Originally Posted by tedmagnum View Post
    last time i asked someone that... i got slapped
