Results 1 to 7 of 7
Thread: battery trouble
    glenn's Avatar
    glenn is offline Junior Member
    dublin
    battery trouble
    hi lads havent posted in while but have been here lurking in de background have a little problem you guys mabey able to help me with regarding battery chargeing .
    yuasa battery charged 12.54
    tickover 14.5
    2500 rpm 14.3
    5000 rpm 14.3
    lights on
    tickover 11.8
    2500rpm 12.0
    5000rpm 12.0
    go for 8 mile spin lights on full
    battery reads 12.2
    tickover 12.7
    2500rpm 13.1
    5000rpm 13.1
    lights on
    tickover 11.8
    2500 11.9
    5000 11.9
    just wondering do these figures seem ok cause battery seems to drain fairly quickly plus heated grips disconnected. battery new and no other extras to drain battery just wondering what problem it could be thanks lads
    c405's Avatar
    c405 is offline Junior Member
    Sep 2008
    Spain
    Re: battery trouble
    My RD04 have had the same simptoms. The way to fix it was to change the reg/rec, I've fitted one from Electrex and it works fine.
    Since then no charging troubles.
    Wangit's Avatar
    Wangit is offline Tea boy
    Oct 2008
    Mid Wales on the borders
    Re: battery trouble
    I would probably plump for REG/REC. Once again very similar symptoms on my old CX500. It is now fine with a change over.
    Re: battery trouble
    Quote Originally Posted by glenn View Post
    tickover 14.5
    2500 rpm 14.3
    5000 rpm 14.3
    lights on
    tickover 11.8
    2500rpm 12.0
    5000rpm 12.0
    battery reads 12.2
    tickover 12.7
    2500rpm 13.1
    5000rpm 13.1
    lights on
    tickover 11.8
    2500 11.9
    5000 11.9
    New regulator required, very common fault and easy to change, remove side panel then two bolts and a plug I think.
    Whealie's Avatar
    Whealie is online now Wing Commander
    Lewisham, SE London
    Re: battery trouble
    Wemoto is your friend.
    Rge/rec.
    Do it now before it fries some bulbs and the destroys the battery good and proper.
    glenn's Avatar
    dublin
    Re: battery trouble
    cheers lads just ordered one needed the extra bit of advice will get back an let you know how its going when i get it
    glenn's Avatar
    dublin
    Re: battery trouble
    tanks for advice lads reg rectifer replaced and bike running as it should
  1. xr trouble
    By matt1234 in forum XR
    Last Post: 12-01-09, 08:42 PM
  2. Flat battery or dieing battery?
    Last Post: 16-12-08, 02:30 PM
  3. trouble
    By sapper in forum Dominator / FMX
    Last Post: 10-10-07, 10:20 PM
  4. I'm in trouble
    By Sharribee in forum Chatter
    Last Post: 16-02-07, 04:02 PM
  5. Trouble getting on
    By Taz in forum Problems with the forum?
    Last Post: 01-02-07, 09:49 PM
