Originally Posted by
fergus1964
on the rd03 the wee cap thing from the brake pad pin doesn't fit. it's too big. I think the choke plunger on the rd03 might be smaller. i might be wrong, but i definitely tried this out when playing with the carbs from a bros 650, trying to fit them to the rd03. The bros carbs have a bigger bore diameter, giving the engine more low speed punch, but don't quite fit within the rd03 frame rails, so i had to put the old ones back. the rest of the bros engine is identical so far a mounting points are concerned, but has a close ratio set of gears. a project for another day...
