I'm busy taking my carbs out of my RD03 to lend to Holla so he can check if his constant misfiring problem is carb related. I've managed to remove all connecting tubes, cables and rubber bits except for the choke valve nut.
The problem is that the nut in question seems to be made of plastic and some fine person in the past has rounded it off nicely so that a spanner just slips round. There appears to be a small plastic piece located right up against the carb, which may be knurled and might turn (although it's too tight for me to turn with my fingers) or it might just be a seal, I'm not sure which.
So the options are try to turn the knurled bit with a pair of pliers or try to turn the nut bit with a vice-grip. Either way I'm going to end up trashing this silly bit of plastic. Anybody have any clever suggestions for this before I do the deed?
