Results 1 to 5 of 5
Thread: brakes
    Whealie's Avatar
    Lewisham, SE London
    brakes
    anyone got an RD04 and an RD07 who could compare the front brake callipers?
    David Silver yesterday told me that they are different and the RD04's are no longer made.
    Are they interchangeable?
    Re: brakes
    I can lend you a spare RD07 caliper (or two) to try for fit if you like.
    scarfacehugo's Avatar
    Jul 2008
    London
    Re: brakes
    I'm quite sure that they're the same(95% sure). Maybe the pistons are different sizes, but everything else is the same, including the pads and the mounting holes.
    Bolton, Lancs.
    Re: brakes
    Had a look earlier, put 07 caliper and bracket to the 04, the holes/mounting points line up. . . . so i would say they are inter-changeable. . . . i think you would also need the 07 caliper brackets as the pads mount differently, ie 04 - 2 pad pins, 07 - 1 pad pin.
    Whealie's Avatar
    Lewisham, SE London
    Re: brakes
    Cheers guys - pics anyone?
    I now have odd callipers on both bikes. I have original RD04 left calliper on both bikes and some other calliper (which fits) on the left. The other calliper takes thinner brake pads so they wear out faster.
    Will post picks of mine ASAP.
  1. MOT and brakes
    By subby in forum Transalp
    Last Post: 22-11-08, 09:36 AM
  2. Better brakes
    By Simon WS in forum Dominator / FMX
    Last Post: 20-08-08, 10:19 PM
  3. Brakes again
    By markh in forum Africa Twin
    Last Post: 25-02-07, 05:29 PM
  4. BRAKES.....
    Last Post: 22-01-07, 08:53 AM
  5. Brakes
    By z-weiser in forum Mechanical Advice
    Last Post: 29-12-06, 09:49 PM
