Results 1 to 3 of 3
Thread: leaking sealrings
    frankvdb is offline Junior Member
    Mar 2009
    Antwerp, Belgium
    leaking sealrings
    Hi there,
    I'm driving a AT RD07 from 1995
    Right now I'm having a technical problem:
    The motor leaks oil on both the pignon sealring (front sprocked) and the gear-shifter sealring.
    I've changed both sealrings but the leaking is still there.
    Yesterday I checked the sealrings again and I found out that there is a lot of play on the pignon shaft, I can move the shaft 1-2 mm up and down. I'm pretty sure it is not supposed to do so.
    Who can give my advise:
    1. should there be play on the shaft?
    2. What can be the cause of the leaking (shaft worn out, need oversize sealring,...)?
    3. do I need to change the bearing on the shaft (I hope not, that means I have to take the motor appart
    every advise or tip is more than welcome.
    I hope to hear from you guys,
    Frank
    BobA's Avatar
    BobA is offline xRv PiMp ;-)
    Sussex Riviera
    Re: leaking sealrings
    Hello Frank
    This is NOT good news I'm afraid.
    There is a very good chance that the gearbox output shaft bearing has failed.
    This is a well known problem, and is caused by a drive chain that is too tight. If the chain is not slack enough, when the rear suspension compresses, the chain goes tight and there are three parts that usually suffer... The rear wheel bearings, the gearbox shaft bearing, and finally the splines that the front sprocket slides onto, on the shaft.
    I'm afraid it seems you may need to replace the bearing, but you should also check the splines on the shaft. Both involve removing the engine and splitting the crankcase.
    It is a very good idea to get a second opinion from your local motorcycle specialist before starting this major job.
    Sorry to bring such bad news.
    Mar 2009
    Antwerp, Belgium
    Hi Bob,
    thanks for your message,
    I'm afraid you're right, I 'll have to open the motor, I ‘m not gonna take any chances on ruining the gearbox.
    The bearings and gaskets are ordered, I hope it wont take to long before I receive them.
    This will be a nice Easter-break project…
    Thanks for your advice,
    Frank
  1. OIL LEAKING from up in engine!!
    By tonyk in forum Africa Twin
    Last Post: 24-01-08, 12:12 AM
  2. brake lever leaking
    By 77rons in forum Dominator / FMX
    Last Post: 10-12-07, 08:56 PM
  3. Help please she is leaking fuel
    Last Post: 16-10-06, 05:56 PM
  4. leaking piston seal
    Last Post: 06-06-05, 09:20 PM
  5. Help please she is leaking fuel
    By Lord Vader in forum Mechanical Advice
    Last Post: 01-01-70, 06:19 PM
