A couple of days ago, I replaced the brake pads, all went smoothly.
At that time, I took the caliper holder from the caliper body, you know that piece of metal that bolts to the forks. This fits to the caliper via two pins protected by rubber boots, one pin sits on the caliper, the other sits on the holder.
The caliper actualy slides on this holder. I lubed these pins and the boots with silicone grease, as per the official Honda Shop Manual's instructions.
Yesterday I replaced the front brake fluid and again all went smoothly.
The front brake performance is great.
But... today I noticed an odd noise from the front calipers when going downhill to enter the garage as I applied and released the brake, you know, with both feet on the ground and the bike almost stopped.
It's this type of "clack, clack, clack" noise.
After parking the bike, I got off and grabbed the left caliper with my hand and wiggeld in several times from left to right and id does have a smal amount of play, hence making the noise. The other side is just the same and it even does this when you gently kick it with the tip of your boot.
I know this noise was not present before, as I do park the bike in the same garage every day but yeasterday it didn't do the noise... byt I also don't remember doing the brake apply-release like I did today.
Now, what can be the source of this? Aren't the calipers designed to have a slight amount of sideways play?
Maybe I misassembled something? I dount it because it's not the first time I took the calipers out but it is the first time I chenged the front pads and removed the calipers from their holders...
Any thoughts?
If you would like to see a vid, I can make onbe in a couple of hours.
Thanks a million.
Cheers.
