Results 1 to 10 of 11
Thread: Single Front Disc option
    Knobblywobbly's Avatar
    Aug 2008
    Bognor Regis
    Hi everyone,
    A couple of questions:
    1. If I removed a front disc and caliper from my @, what would be the difference in braking? I can see that on the face of it, it looks like it would be halved but I donīt think that would be the case. Iīm thinking more of "real world" difference rather than theoretical.
    2. If I went to a single front disc, would fitting a 4-pot caliper make up for the loss of the other disc? Or should I just stick with the 1 disc + standard 2 pot caliper?
    Comments, as always, appreciated
    lootch67's Avatar
    South Ockendon, Essex
    Re: Single Front Disc option
    Are you trying to save on brake pads? One thing you can't accuse the AT of is that it's "overbraked".
    futter's Avatar
    Jul 2005
    Suffolk
    I looked at this from the point of view of fitting a set of USD forks (eg) KTM 640 and fitting a 320 mm disc. The maths escapes me but essentially braking stays the same to a point as you have to apply greater force and therefore greater heat biuld up is created.
    There is an argument for forks twisting but if set up properly I can't imagine that is an issue.
    You could mount a 320mm disc on your hub and fabricate a caliper mount. VFR calipers are a fav of some SM riders.
    futter's Avatar
    Jul 2005
    Suffolk
    One thing I will say is that I suspect that a 320mm disc with decent caliper would be better than the AT standard brakes.
    Well my mate tried only using a single front brake a few years ago when he bent one disc so much it was eating his pads and caliper. Braking wasn't hugely bad but no one would ride in front of him down hills.
    Aug 2008
    Bognor Regis
    I do hope that the caliper in the picture is the one he WASNīT using
    My front wheel has started to rot and will need replacing very, very soon. A friend of mine has offered me a 21" front wheel from a Suzuki DR750 which I should be able to fit with the appropriate spacers. But the DR has only 1 front disc, hence the questions.
    futter's Avatar
    Jul 2005
    Suffolk
    Why not lace the DR rim onto your hub. I am having a DRZ rim laced onto mine as I type. Therefore you keep the brakes and get a new rim. The chap doing mine charges Ģ50 a rim if you are near felixstowe. He has done wheels for me in the past and is rather good.
    Aug 2008
    Bognor Regis
    That was the original plan. However I spoke to a local wheelbuilder today who told me that, due to the angle of drilling of the rim, the hubs need to be near-as-dammit the same diameter for that to work. If theyīre not then the spokes will bend when lacing the rim. Iīve no reason to doubt what he said, and as I donīt know the diameter of the hubs I thought Iīd ask about some other scenarios - I canīt be lucky enough to find that the hubs are the same diameter!
    futter's Avatar
    Jul 2005
    Suffolk
    Speak to the chaps at Hagon. They advised me about the DRZ rim and between us were sure it would fit. Your chap is right to an extent but there is some give in the measurements.
    Aug 2008
    Bognor Regis
    Thanks mate, Iīll give them a call.
    Just found that the wheel spindles on a DR are a different diameter, so the whole wheel wonīt fit
  1. Wanted: XL600LM or XR Front Disc Cover/Shroud
    By BobA in forum For Sale / Wanted
    Last Post: 19-03-09, 12:30 PM
  2. WANTED: Dominator Front Disc/Exhaust
    By mini-thumper in forum For Sale / Wanted
    Last Post: 30-03-08, 02:03 PM
  3. Acerbis front disc and fork protectors
    By sheep911uk in forum XR
    Last Post: 24-03-08, 08:52 PM
  4. 600 single disc to twin disc conv
    By mayb1961 in forum Transalp
    Last Post: 06-03-08, 09:23 PM
  5. twin disc front end to fit a single disc bike?
    Last Post: 13-04-06, 04:19 PM
