Results 1 to 2 of 2
Thread: RD03 front brake pipe routing
    holla is offline Senior Member
    Oct 2008
    manchester
    Hi all, How have you routed a braided front brake pipe on an RD03 without it catching on anything under fork compression or on full lock ??.
    I've ordered a 1000mm line as the 1050 one is a bit long but as you know the braided lines are considerably thinner than the original rubber ones so how have you secured it in the clamp on the lower yoke ? - wrap some tape on the pipe to make the gap up or leave it loose in the clamp ?.
    Kjell Lindberg's Avatar
    Sweden
    Re: RD03 front brake pipe routing
    Hi Ian.
    I just left mine alone.
    Just as you say, the braided hose has a smaller diameter, never the less,
    I just left it as it is, and have had no problems with it for three years now.
    Let me know if you need pictures.
    //Kjell
  1. RD03 front brake issues !!!!!
    By holla in forum Africa Twin
    Last Post: 10-04-09, 11:56 AM
  2. RD03 / RD04 Front Brake Caliper
    By BobA in forum Africa Twin
    Last Post: 12-04-08, 02:16 PM
  3. Wanted Rd03 Tail Pipe Not Std
    By hippos xr6 xrv660 in forum Africa Twin
    Last Post: 28-02-08, 06:10 PM
  4. RD03 front brake master cylinder....
    By Ratrap in forum Africa Twin
    Last Post: 09-07-07, 08:20 PM
  5. One-off brake pipe needed.
    By steveR in forum Mechanical Advice
    Last Post: 01-06-07, 03:53 PM
