Results 1 to 10 of 14
Thread: Overheating boiling battery rectifier problem
    anton88's Avatar
    Finally, i have killed my rectifier - think it got a bit hot yesterday. only just managd to start the bike when i was out yesterday, and when i finally got home it wouldnt start off the button - lots of clicking and fizzing noises
    took the side panle off and there was a small amount of steam/fumes coming from the battery area
    So disconnected it quick and took it outside to cool down. It wasnt boiling, but was very hot to touch.
    Looks like i'll need a new batery as well.
    Have checked previous threads, but is it any particlar R6 / R1 unit that will fit ????
    + would a Fazer 600 unit do the job - these all seem to have a wiring harness still fitted which i can 'hack about' whereas the r6/r1 units dont.
    cheers ant
    AlanH's Avatar
    Bristol, UK
    Re: Overheating boiling battery rectifier problem
    I've not seen a Fazer 600 unit used but just 'cos it hasn't been done doesn't mean it's not a good idea.
    It looks like just the job:
    http://www.fazerspares.com/items/127...-rectifier.htm
    An approach with the R1/R6 unit is to ditch the Honda connectors and use spade connectors to attach directly to the regulator. As the Fazer 600 unit has wires on it, you could just reuse the existing connectors off the fried unit, that would be just the job.
    It maybe worth finding out the alternator output on the Fazer 600 to compare with the AT. Maybe the Fazer 1000 may be a better bet:
    http://www.fazerspares.com/items/147...-rectifier.htm
    Lucky you haven't fried your tacho and CDI by the sound of it.
    anton88's Avatar
    Cheers Alan, rather than following my usual style of being completely different to everyone else, ive ordered an R1 rectifier. Found some good info on a vfr forum which had good reports on the R1 unit, so see how it goes.
    All being well, i'll put some pics up at the weekend (fingers crossed).
    Xander's Avatar
    Jul 2006
    Lichfield
    Quote Originally Posted by anton88 View Post
    Hey Anton, I have not been here for a very long time and just popped in to see what is going on and saw this tread. If your bodge does not work out, I am getting rid of a brand new electrex world R/R for an AT. Details are over in the HUBB for sale section. (I dont know if i am allowed to post a link about a sale.. so i wont. but the post is called FS UK: Honda Africa Twin RD07a parts). Good luck with it.
    X
    Whealie's Avatar
    Whealie is online now Wing Commander
    Lewisham, SE London
    Hi Xander, where you bin? Why you not playing on here any more?
    anton88's Avatar
    Cut out the old rectifier over the weekend, soldered spade connectors onto the wiring and wired up easy peasy - took about ten mins
    plugged it in with new battery and hey presto - sorted.
    £20 for an R1 rectifier off ebay and £35 for a new battery (sure ive killed the old one )
    Seems to be running ok :
    balee's Avatar
    balee is offline balee
    Mar 2007
    cluj, romania
    hey anton88!
    i am also getting a replacement reg/rec its from an r6, i think it has the same sonnectors possibly be the same part. i was wondering how did you connect it to the wireing. i mean how did you know wich wire goes where? some advice maybe a photo would really help.
    thanks in advance!!
    anton88's Avatar
    Hi Balee,
    Heres a picture with the terminals that may help you (its from a different bike, but terminals are exactly the same):
    The three terminals in a row are for the yellow wires - does not matter what order you fit them in).
    Looking at the terminals exactly as above, the left top one is to the battery, and the right top one is ground.
    IF you have a spare black wire on an earlier bike, cover this up with isulation tape and DO NOT connect it to the rectifier (Alan H has commented about this elsewhere).
    Hope this helps .
    Ant.
    balee's Avatar
    Mar 2007
    cluj, romania
    thanks a million!!!
    cant wait to fit the new reg
    PerfectStranger's Avatar
    PerfectStranger is offline Senior Member
    Mar 2008
    Lisbon, Portugal
    Why are you driving on the wrong side of the road?
    Good work with that R/R
  1. Battery/alternator/rectifier?
    By Shayite in forum Transalp
    Last Post: 23-11-08, 07:27 PM
  2. regulator/rectifier problem
    By philhennem in forum Africa Twin
    Last Post: 30-05-08, 05:42 PM
  3. Battery problem ...
    By croydon@twin in forum Mechanical Advice
    Last Post: 03-10-07, 08:25 AM
  4. xrv overheating part 2 + new problem
    By expat Stu in forum Africa Twin
    Last Post: 01-09-05, 10:13 PM
  5. XRV 650 overheating
    Last Post: 24-08-05, 12:29 PM
