Results 1 to 7 of 7
Thread: Facet Fuel Pump, Fuel through the roof
    pxlpig is offline Senior Member
    Mar 2008
    CANTERBURY
    Hi all, Long time no hear!!
    Honda Fuel Pump packed up finally...after 40k!
    Got a Facet Fuel Pump from the wonderful folks in the shop here, all fitted...finally worked out how to get a square into a round hole....., problem i have now got is that my fuel consumption has sky rocketed, i will be lucky to get 130miles from a full tank doing normal riding, used to be able to get 150 - 160miles outta full tank......any siggestion guys n gals?
    2000, RDO7, Black, Arrow Exhaust, Black Powerbronze screen, Corbin Seat, Hagon Shock, Black Crash bars, Garmin Nuvi, and a Shoei Hornet.
    Re: Facet Fuel Pump, Fuel through the roof
    Check the mixture screw and carb balance.
    It is possible that as the original pump degraded the mixtures were altered to compensate, a new strong pump now needs to be tuned to your needs.
    Steve C's Avatar
    England - landed in Yorkshire
    That's exactly what happened with mine - old pump getting steadily weaker and delivering less fuel and that was accommodated steadily at each service. When I switched pumps, I was in trouble until next service and then all set back to right levels and all fine ever since.
    !Boris!
    !Boris!!Boris!
    Kamaddick is offline Tavistock@
    Oct 2008
    Tavistock
    Sorry to burst your bubble but I am getting well over 200 miles per tank and no, not taking things particuarly easy either!! Cant see it being the fuel pump. Carbs?
    Steve T's Avatar
    Steve T is offline Hill Rider
    Oct 2004
    RidingAlongOnACarousel
    200 - 220 before reserve required.
    Get the machine serived - plugs, air filter, tappets, then get carbs balanced.
    Just my tuppence worth
    Steve T
    Mar 2008
    CANTERBURY
    Nice one folks, I'll get the puppy serviced, think it's due for a BIG service anytime now....... good pump though, it eveb clicks mega loud just before i need to switch over to reserve.....an audable warning is incuded free....cant do any good for the pump though, so always try to fill up before that point.....generally at the 115mile mark!
    russt1969's Avatar
    russt1969 is offline Long Way Home 2010
    Aug 2008
    Cheam, Surrey.
    Keep us informed. I've just bought one too
  1. Facet Fuel Pump
    By Annette in forum Africa Twin
    Last Post: 12-04-09, 08:43 PM
  2. Facet fuel pump
    By AfricaQ in forum Africa Twin
    Last Post: 08-04-09, 12:22 PM
  3. Facet fuel pump - help please
    By Sir Royston in forum Africa Twin
    Last Post: 18-11-07, 11:20 AM
  4. Facet fuel pump
    Last Post: 06-06-07, 10:29 PM
  5. Facet Fuel Pump
    By DaveS in forum Mechanical Advice
    Last Post: 19-02-06, 12:55 AM
