Results 1 to 10 of 10
Thread: Replacement RD03 rear shock
    holla is offline Senior Member
    Oct 2008
    manchester
    Hi all, I knew my rear shock would need replacing sometime as it didnt look great but in a week where i've rebuilt my front caliper with new pistons,seals,pads and brake line, ordered the bits for the fork overhaul and just received a complete clutch assembly i was out on the Africa twin and after a short ride i parked it up.
    I came back about 45 mins later and there was a pool of liquid under the bike underneath an overflow pipe. On closer inspection i realised that it was the overflow pipe from the rear shock and what infact was happening was fluid was leaking from the shock and running down the outside of the overflow pipe
    I've seen the rebuild service on e bay but can they do it for that price if the shocks completely foooked ( piston rod scored etc etc).
    I have sent an e mail to hagon as they dont list one for an RD03 but i'm sure they can do one but i was wondering will the remote reservoir be the same size and fit where the original one does ??
    has anyone fitted an aftermarket one and if so:
    - what make ?
    - how much ?
    - look and fit like the original ?
    - pictures please
    cabbage2404's Avatar
    cabbage2404 is offline Senior Member
    Jan 2006
    South Wales
    Re: Replacement RD03 rear shock
    Fook me Holla, you're having some problems with this bike aren't you mate ??
    I fitted a Fournales air shock to my RD03, it weighs around a third of an oe shock and is fully adjustable via a high pressure hand pump.
    Cost me £400.
    I have the oe shock in the shed if you are interested £40 plus postage if you are interested.
    GS owner (The Suzuki one, not the Bavarian Monster)
    Kjell Lindberg's Avatar
    Sweden
    Technoflex (Wilbers)
    AlanH's Avatar
    Bristol, UK
    Check out these guys...
    ABE Suppliers of High Quality Brake Disks, Fork Stanchions and Shocks - Shocks
    I was going to use them for my RD04 but then a new shock came up on eBay for a bargain price. They sounded like they knew their stuff and can rebuild pretty much anything. They can manufacture new damping rods if your rod's pitted too.
    Give 'em a call and have a chat.
    Oct 2008
    manchester
    Wow guys, 3 replies in 10 minutes !!!!
    Cabbage, I was expecting the shock to go sometime just not this week. All the other things i was going to do when i strip and repaint the frame but i realise now the clutch cannot wait till then. The bike is a minter so i dont mind spending the money on it. There really wont be anything left to do when i've done all this........................... apart from maybe new rims ??.
    can you send me a pic of your shock, is the damping rod in good condition, i'm very interested if its ok. I might just send it straight away to get refurbished rather than it going in another 6 months again.
    I'll give ABE a bell and ask them a rough cost to refurbish a genuine shock.
    Kjell how much was that thing ?? it looks expensive. I do love my @ ..................... but maybe not that much
    Sweden
    Advanced high and Low Speed
    This shock provides you with more comfort, control and safety/trust of the bike.
    Suitable for:
    - Competition
    - Track races
    - Dirt (MX)
    - Off-Road
    - World travelling
    Selling Points:
    - Compression low speed adjustable with 35 clicks.
    - Compression high speed adjustable with 35 clicks.
    - Rebound damping adjustable 50 clicks
    - Tailor made and adjusted to the weight and driving style.
    - Suitable for bikes with less space for a reservoir.
    - We can make all our shocks longer or shorter to full fill your needs.
    - Special wishes according to the spring colour is possible.
    - Ride height adjuster possible
    - Hydraulich Pre-load adjuster possible
    Technoflex suspension technology - Offroad Products
    631-000-00Typ 631 Competition Ø 36 mm € 649,-
    Wilbers Products GmbH - Ihre Fahrwerksmanufaktur! - Motorrad Tuning in Niedersachsen - Wilbers Online Shop - www.wilbers-shop.de -
    AlanH's Avatar
    Bristol, UK
    Quote Originally Posted by holla View Post
    They quoted me between £50 and £100 depending on whether they needed to remanufacture a new damper rod or not. They could also do stuff at additional cost like cleaning up the shock body and powder coating the spring too. Normally it comes back looking like it did when it was sent (except that it works again of course).
    Oct 2008
    manchester
    OUCH Kjell !!! I think a more "standard" one will be fine then
    Thanks Alan, I think i'll give them a ring as that looks favourite.
    Thanks all
    antti's Avatar
    antti is offline Senior Member
    Aug 2008
    Southern Finland
    I have Technoflex in mine, I had one also in my ex GS.
    I think they are good enough for amateur like me and at least a bit cheaper than Öhlins, and can be rehauled.
    I don`t have hydraulic preload setting in mine, it would be a big +.
    But as I understand right, it can be added afterwards.
    G/S project bike.
    Oct 2008
    manchester
    Quote Originally Posted by cabbage2404 View Post
    I am interested !! i've sent you 2 messages but youve not replied. Can you not get your messages ??
    Please get in touch as i'm desperate for a shock, Its leaked all its fluid now so i cant use it till i get another.
  1. Best rear shock replacement?
    Last Post: 17-02-09, 07:00 PM
  2. Replies: 3
    Last Post: 17-06-08, 10:36 PM
  3. rear shock TA
    By bikecrazy100 in forum Transalp
    Last Post: 24-11-07, 08:03 PM
  4. Rear Shock
    By TAY in forum Transalp
    Last Post: 01-01-07, 12:58 PM
  5. Replacement rear shock - experience/ recommendations?
    By ghostridergary in forum Africa Twin
    Last Post: 22-04-05, 10:11 PM
