Results 1 to 10 of 16
Thread: centre stand spring
    Whealie's Avatar
    Lewisham, SE London
    centre stand spring
    My centre stand had rotted. So bad was it that I had to buy an angle grinder to cut through it.
    First I put the bike on a paddock stand up the kerb to give me more height to work with.
    Eventually it pinged loose and I could knock out the axle.
    When it came to fitting the new one I remembered reading how hard it was to get the springs connected and that people had used coins to prize the springs apart. I tried this:
    But it seemed a futile way of doing to me - I was simply damaging lots of coins.
    So, I gripped the spring with tightened Mole Grips and then used one of those ratchet straps wrapped round the paddock stand at one end and connected to the Mole Grips at the other to pull the spring.
    Easy-peasy and I heartily recommend it.
    AlanH's Avatar
    Bristol, UK
    Re: centre stand spring
    That's either a stroke of genius or cheating. I'm not sure which.
    (Actually I'm just jealous 'cos I didn't think of it).
    chronyx's Avatar
    Surrey, UK
    Nice one Whealie!
    stageonesimmo's Avatar
    Nov 2006
    I've kept the spring pulling tool (a long hook type affair with a handle) that came with my daughter's trampoline for just such jobs - dont know how my knuckles will fare though!
    Nice (mis)use of kit though, love it.
    Adapt, improvise and overcome...............
    Snaphappy's Avatar
    Mar 2008
    ExPat in Germany
    And now with the left over coins buy some grease to protect the new one
    Jacqueslemac's Avatar
    Jacqueslemac is offline Top Cat
    Norfolk and Normandy
    On Saturday I spent almost an hour trying to get the springs fitted to mine. I broke one screwdriver, bent another and have a black fingernail.
    I thought about using a ratchet strap, but don't have one. I think I'll buy one having seen the theory work.
    In the end, the spring somehow jumped into place, accidentally. I still don't know why it worked when the previous 53 other attempts hadn't quite done so.
    1990 Africa Twin RD04
    2003 Triumph Tiger 955i
    "Do not indulge in dreams of having what you lack, but reckon up the blessings you do possess. Then reflect with gratitude how you would crave them if they were not yours." Marcus Aurelius
    Quote Originally Posted by Jacqueslemac View Post
    Each attempt stretched it slightly so on 54 it just was easier.
    Magnum PI is offline hondabore
    Jan 2008
    devon
    Hi weelie did you also find a way to fit the centre stand without removing the exhaust! As thats the bit that puts me off bying a centre stand.
    AlanH's Avatar
    Bristol, UK
    RD04 stand goes on and off without removing the exhaust.
    Jan 2008
    devon
    Mines a rd07 2000 .are they that diferent
  1. centre stand
    By Magnum PI in forum Africa Twin
    Last Post: 27-04-09, 08:27 PM
  2. Centre stand
    By suds750 in forum Africa Twin
    Last Post: 21-02-09, 05:11 PM
  3. Centre stand
    By thetimkirby in forum Africa Twin
    Last Post: 23-12-08, 01:29 PM
  4. SW Motech Centre Stand Spring
    By kenn in forum Transalp
    Last Post: 24-10-07, 05:57 PM
  5. Centre Stand Spring.
    By Adnoh Plasnart in forum Transalp
    Last Post: 04-06-07, 02:31 PM
