Hello. The other evening I was driving home, and as you do when its starting to get dark I went to put my head lights on and nothing! I was driing through the Drumochter Pass, and ifany of you know it then you will know its not a place to loose your lights! Anyway... The next morning I had a look at the fuse box and the 20amp fuse for the head lights was fried to a crisp, even some of the plastic fuse box surrounding it had melted a wee bit. So I got in there with a small screw driver to pick out the frazzled crap, and put the replacement fuse in, lights worked fine. So for the next few hours I rode around with the lights on dipped, checked the fuse the next day and all was fine, no signs of burning or browning up, put the lid back on the fuse box and nothing! Argh!!! If I pull and tweak the box then I here a sizzling sound but no lights, also the box on the dash with you side stand light, oil light etc sounds like its buzing/sizzling. So Im thinking its a loose connection somewhere, maby the wire is touching metal? So anyway, do you think I may have to get a new fuse box as Im not sure if the port for the 20amp light fuse is workable anymore? Where could I get one. Also has anyone else experienced this? Thanks alot, sorry about the long read!!!
so ended up getting new fuse box from e-bay from a breakers, cost me £6.00 plus couple of quid p&p. Came complete with fuses, diode and harness.
