Re: Well it ain't the choke!
I had a similar problem recently and I eventually traced it to the chain and sprockets. I had checked for tight spots, chain tension and kept if fully lubed (scottoiler) but it still lurched noticably at low speeds. I didn't think the chain/sprockets were particularly worn because I still had loads of adjustment left but then it started getting noisy so I bit the bullet and fitted a new set. Result - the noise stopped, and the ride was once again smooth as as @ should be. Not much help to you I'm afraid but it seems like you've tried everything else.
Dylan
__________________
1997 RD07A, Red, Remus Ti Pipe, Goodridge Hoses, Scottoiler, Centre Stand, Heated Grips, Givi Engine Bars, Facet Fuel Pump, Double Wide Foot Pegs, Renthal Dakar High Bar and 25mm risers, 66K miles 2002 RD07A, Fast Black, Remus Alu Pipe, Goodridge Hoses, Scottoiler, Centre Stand, Heated Grips, Givi Engine Bars, Facet Fuel Pump, K&N air Filter, Fiamm Horns (awesome!), Bagster Tank Cover & Bag, Pooratech Panniers, 32K miles |
Cush-drive rubbers in the sprocket carrier - had it before on a Harley MT - took ages to find it, but a new set cured it instantly and its worked for someone on here with an @ as well - worth a shot.................
__________________
'In the absence of orders, go out, find something.... and kill it!: Gen Irwin Rommel. ![]() Just not in the 'Safehouse', right! |
Gee I have a possibly related issue, or maybe not it might be normal.
When I give a bit of throttle and release, ie load the drive system up and release, there is a bit more drive lash than I'd like. I have no idea if it's normal or not. There's no great noise but I can detect some noise/lash. Could be just worn cush drive rubbers at 35,000kms? Chain and sprockets were replaced by PO. I do have a new chain rubbing block he gave me, guess the old one is still ok since PO didn't actually replace it. I'll have to clean it off a bit to tell. I think my chain has plenty of slack in it, it isn't tight at all and measures about 1 1/2 inch slack by the MK1 eyeballs. So first of all, is it normal to have a bit of clack/lash in the Africa Twin drive system? I guess the reality is I have to disassemble my chain/drive and clean and check everything. One more thing, I noticed my chain has a master link, should I have this replaced with a rivet type? Depending on the type of chain he put on, I may replace with an Xring chain because I hate cheap chains and would like to preserve the sprockets as long as possible. He may not have considered that important, since he sold the bike.
__________________
-- Jim Davis, Owner, Eastern Beaver Company: http://easternbeaver.com/ - Motorcycle Electrics. Check out my new fusepanel, the PC-8! 2007 Suzuki DL1000, 1988 Africa Twin 650, Transalp 400V Super G Riders, Tokyo Riders, VSRI |
| Bookmarks |
| Tags |
| choke |
| Thread Tools | |
| Display Modes | |
| Why does my choke do this? | beanfeast | Dominator / FMX | 1 | 17-11-08 02:59 PM |
| SLR choke | beanfeast | Dominator / FMX | 9 | 01-10-08 12:26 PM |
| Choke....again | YEN_POWELL | Africa Twin | 36 | 13-07-08 05:37 PM |
| xrv 750 choke | jabba | Africa Twin | 13 | 12-12-06 08:05 PM |
| Choke | YEN_POWELL | Africa Twin | 8 | 12-01-04 11:42 AM |
