Results 1 to 3 of 3
Thread: CDi interchangeability ?? (04 1992 africa twin)
    Grizz is offline Senior Member
    Jan 2005
    closer than you think.....
    Morning all,
    What other cdis will fit rd 04 1992 africa twin??
    Simple question really, any ideas ??
    Cheers,
    Rian
    BobA's Avatar
    BobA is offline xRv PiMp ;-)
    Sussex Riviera
    Re: CDi interchangeability ?? (04 1992 africa twin)
    BobA's Avatar
    Sussex Riviera
    Also, if you're replacing your CDI because of a fault with it, a common failure is the connectors on the CDI breaking away from the PCB inside the sealed box. This either happens through vibration, pressure or dry joint I'm guessing.
    If this is the case, there is a well documented DIY fix which anyone with a bit of soldering iron savvy can do.
  5. The Following User Says Thank You to BobA For This Useful Post:
    mad hatter (06-01-12)
  1. Crossing Africa on Africa Twin
    By Egypt xrv in forum Travel
    Last Post: 29-11-08, 02:02 PM
  2. XLR125/200 parts interchangeability?
    By Bill Badger in forum XL
    Last Post: 01-09-08, 02:04 PM
  3. 1992 xtz660 tenere
    By eugen1 in forum Other Bikes
    Last Post: 22-01-08, 09:55 PM
  4. 1992 Africa Twin
    By Tybalt in forum Africa Twin
    Last Post: 22-09-07, 04:20 PM
  5. 1991-1992 Africa Twin
    By funkman in forum Africa Twin
    Last Post: 08-08-05, 10:00 PM
