That's a top mod Scarfacehugo i think that you are going to be busy......
IT IS BETTER TO TRAVEL ONE MILE THAN TO READ A THOUSAND BOOKS (CONFUSIUS 500 BC/ISH)AND A BIG UP TO IBN BATTUTA
ADVERTISE HERE.
Absynth eye dropssee things in a new way
Hi mate
Email sent let me know if you get it
cheers![]()
also sent pm -hopefully its arrived??![]()
Here it is...
PICT6811 on Flickr - Photo Sharing!
the modified linkage rods for Antony's AT 1 cm longer than stock.
I know that they dont look an nice as the stock thing, but I dont like to grind off the welding because it makes it weaker, and as I see it, I rather have it strong than pretty.
Hi Hugo. What do you think about the possibility of shortening a linkage slightly to give me a higher bike? I haven't looked into how much to shorten it by yet and I know that there are clearance issues with the chain slider but a couple of inches more height would be perfect for me.
Dylan
Hello Dr!!
Nice to ear from you again.
Shortening is not a problem, and even easier than the other way, but I have never tried it on a bike. Dont know about the secondary effects.
I've ran out of spare links to cut and I'm finding hard to get them, but if you dont mind being the "lab rat" (for a change), send me one, I'll do it.
What size rear sprocket are you using?
Email me if you're up for it.
Cheers !
I think we can cut 6 to 8mm to your rods without any side effects to the chain slider or any other suspension problem. I'm studying another way to do it but it's going to take some more time to get it to work.
Waiting to ear from you
Hi
check out this link
The Africa Twin thread - Page 260 - ADVrider
and also
The Africa Twin thread - Page 261 - ADVrider
xrv hulman seems to sugest 1 cm of shortening can raise the bike by ten cms
he has change front end too so not sure if the 10 cm is due to the rear end mod or front or combination of both
let me know how you get on as really would like to raise mine![]()
