Results 1 to 10 of 11
Thread: Protecting the frame underseat area
    chronyx's Avatar
    Surrey, UK
    Just in the garage (Isn't wifi great) and thinking about how to keep the frame rails under the seat protected, it's obviously an area that gets stone chipped as evidenced by the amount of rust that was there.
    I have a few ideas:
    - Wrap aluminium duct tape round them
    - Wrap black plastic 'duck'(?) tape on them
    - Cut up some old inner tubes and either zip tie or superglue in place
    Any other ideas? I think it would be silly not to do something at least seeing as it's just been re-painted.
    Re: Protecting the frame underseat area
    Keep the bike indoors and don't ride it.
    That way no stones will chip it.
    Are you sure it is stone chip and not just wear and tear form the seat rubbing?
    chronyx's Avatar
    Surrey, UK
    On the underside?
    Very sure!
    Snaphappy's Avatar
    Mar 2008
    ExPat in Germany
    Problem is with the underside if you allow anything in under the tape / innertube it will act like rubbing compound and rust away undetected
    you need summit like a high mounted hugger bolted to the frame but not in complete contact, could you fabricate something from PE heat treated to keep clearance
    chronyx's Avatar
    Surrey, UK
    Beyond me I'm afraid!
    Wonder about this stuff
    Biketart.com - Frame Wrap
    Zenarchy's Avatar
    North East UK
    I came across this stuff recently:
    Plasti Dip - Flexible air dried coating, Brush Dip and Spray from £5
    As snaphappy says it might be a worry about it rusting away undetected underneath it, and it retaining water that can't evaporate, but if it's a painted surface underneath I'm not sure if that would be an issue as long as it doesn't get damaged (not sure).
    You can get it in spray cans too. The spray on stuff does claim to prevent corrosion, though how well it works I have no idea.
    There are some other videos on there about it too.
    Tye's Avatar
    Tye
    Tye is offline Junior Member
    Jun 2009
    UK
    Helicopter tape. Like a heavy duty sticky-backed plastic.
    We use it at work on the leading edge of wings/ sidepods etc, anything that picks up stone damage.
    I've removed the plastic frame guards on my trail bike and put this in place.
    chronyx's Avatar
    Surrey, UK
    Sweet thanks guys!
    Lord Stig's Avatar
    May 2004
    West Lothian
    To be honest, I'd go the 'car' route and use a dedicated stone chip paint (once the members are properly painted and rust free). It's an area that's mostly covered in mub and doesn't get seen anyway. You don't have to have the bitumen-based stuff either.
    Zanzibar's Avatar
    Zanzibar is offline Member
    Feb 2009
    European Union
    Aye, ye need a lang spoon tae sup wi' a Fifer
  1. where shoould i go? and anyone from the bournemouth area??
    By nasher123 in forum Meet Ups / Rideouts
    Last Post: 11-11-09, 11:20 PM
  2. Underseat storge area lock removal
    Last Post: 14-04-09, 06:48 PM
  3. another new member from Cardiff Area
    By cmj in forum I'd like to introduce myself....................
    Last Post: 23-12-08, 02:41 PM
  4. protecting wheels
    Last Post: 01-05-08, 07:22 PM
  5. hi new in the area
    By kolbotex in forum Dominator / FMX
    Last Post: 22-01-08, 06:56 PM
