Page 2 of 2 FirstFirst 1 2
Results 11 to 19 of 19
Thread: i have symptoms but no answer
    Knobblywobbly's Avatar
    Aug 2008
    Bognor Regis
    Re: i have symptoms but no answer
    It sounds like your bike is cutting out on one cyclinder. And if itīs happening when it rains then spray your plug caps and HT leads with plenty of WD40 (donīt forget to spray inside the plug caps).
    pxlpig is offline Senior Member
    Mar 2008
    CANTERBURY
    Ok so sounds to me I have a busy Saturday Morning ahead of me, first i will start with the easiest check ignition wires then onto.......WD40....perfume of the god's on the ht leads and plugs etc then move onto the coil spades etc then onto the dreaded carb clean....... hopefully one of these will sort the blighter.
    ...... ooh this is good, could end up saving me a small fortune.....thanks so far folks
    2000, RDO7, Black, Arrow Exhaust, Black Powerbronze screen, Corbin Seat, Hagon Shock, Black Crash bars, Garmin Nuvi, and a Shoei Hornet.
  4. #13
    Mar 2008
    CANTERBURY
    Thumbs up Re: i have symptoms but no answer
    cheers everyone for the advice.
    I tackled the single cylinder issue this morning.....bike out, screws and nuts off, tank off..... easy folks
    Spark Plug leads off WD40 sprayed, plug leads back on start the @ up.....same problem,....
    Check choke plunger thingies... all is fine, check fuel pump...good pulse/squirt of juice exiting pump, check wires from ignition all good..check spadew connectors all brill..... please no...not the carbs......lets just check all four spark plugs, spark plug tool out and fettle away getting the plugs out, back cylinder plugs ok,.... front cylinder....... eurika!!!!
    Front cylinder plugs caked in soot and crap...about 2mm worth all over...hmm, quick clean up and gap check, plugs put back and.....she's alive, she's alive!!!..... not bad for an hours grief
    Now...which plugs are any good to buy.....??
  5. #14
    GSPD750's Avatar
    Calgary, Alberta Canada
    Quote Originally Posted by pxlpig View Post
    Good job!
    Just get the Honda OEM...you know they will work.
    DPR7EA-9 NGK
    Many sparkplug threads here on what is good and what is not.
    I'll stick with Honda OEM.
  6. #15
    oldmotors's Avatar
    oldmotors is offline Member
    Mar 2008
    Timisoara, Romania
    Quote Originally Posted by GSPD750 View Post
    Good job!
    DPR7EA-9 NGK
    Isn't Honda recomending NGK DPR8EA-9 or CHAMPION RA4HC ?
  7. #16
    GSPD750's Avatar
    Quote Originally Posted by oldmotors View Post
    Ooops. You are correct. The DPR7EA-9 NGK is an equivelent but it is rated for cold climate. Below 5 C
    The DPR8EA-9 NGK is the standard plug.
    The DPR9EA-9 NGK is for extended high speed riding.
    It's all about heat range.
  8. #17
    myfirstxrv's Avatar
    myfirstxrv is offline Member
    Bournemouth, England
    On plug subject - I went for iridium. Fit, forget, never have to mess around trying to get the ones out from under the tank ever again
    RD07 Black, new ratios, facet fuel pump, Mitas E07 rubber, homemade top box, centre stand, heated grips, tall screen.
    Speed Triple 955, green
    R1 streetfighter, proper scary
  9. #18
    Maverick's Avatar
    May 2004
    Tilbury, Essex
    Quote Originally Posted by myfirstxrv View Post
    Why is that then are they guaranteed to last forever
    I have seen brand new plugs fail in under 200 miles before and other's last for longer than expected
    Don't trust all the hype.........
  10. #19
    myfirstxrv's Avatar
    Quote Originally Posted by Maverick View Post
    13,000 miles and going strong....hmmm is 13 an unlucky number?
  1. Replies: 3
    Last Post: 09-04-09, 08:55 PM
  2. Definative answer
    By tee pee in forum Transalp
    Last Post: 23-06-08, 10:11 PM
  3. Withdrawl Symptoms
    Last Post: 02-03-07, 12:19 PM
  4. Question n Answer
    Last Post: 25-04-06, 11:37 AM
