Re: i have symptoms but no answer
1. Make sure the battery connections are tight. If they're loose the bike can run badly or cut out altogether.
2. Pull off the low tension spade terminals from the front coil and clean them before re fitting. Any problems here is magnified big time at the exit high tension side, causing the bike to run on one cylinder temporarily. Are the rubber strips on the frame's front down tube both in place. These stop spray/winter salt going onto the connections mentioned.
