Results 1 to 5 of 5
Thread: Fitting Goodridge hoses
    chronyx's Avatar
    Surrey, UK
    Well they are on and the fronts are filled and bled, these were from wezmoto on eBay.
    Have to say I was not impressed with the alternative to the rigid Honda section that goes across the forks, I had to bend the original offside hose mounting bracket in a vice so the new Goodridge T piece could fit (The bottom fork yoke is in the way otherwise) and the nearside hose had no provision from Goodridge at all, the original Honda equipment has a little box with the pipes at right-angles but of course you lose this with braided hoses.
    Improvisation was necessary and they certainly aren't a straight out of the box install which is a shame. Putting a bracket to use on the nearside hose as well would have saved a lot of time and mucking around and cost them nothing.
    tedmagnum's Avatar
    Jul 2005
    liverpool
    Re: Fitting Goodridge hoses
    yer.. they arnt the best fit but they do the job and are pretty cheap.
    P-clips help a lot in keeping them tidy and in place.
    chronyx's Avatar
    Surrey, UK
    Yup - in fairness I have no complaints about the price especially as they don't use a double banjo bolt as apparently that's bad!
    Whealie's Avatar
    Whealie is online now Wing Commander
    Lewisham, SE London
    Must admit I sent mine back and bought the Mervin hoses from Wemoto.
    chronyx's Avatar
    Surrey, UK
    Where were yours from Chris?
  1. fitting Goodridge brake lines
    Last Post: 25-04-09, 03:11 PM
  2. Goodridge Braided Brake lines (e-bay)
    By iainnic in forum Transalp
    Last Post: 06-08-08, 02:03 PM
  3. Goodridge Hoses For Africa Twin
    By 1gear1brake in forum Mechanical Advice
    Last Post: 10-05-08, 09:41 AM
  4. Goodridge brake lines
    By icenian in forum Recommended Dealers / Service Providers / Campsites
    Last Post: 15-03-07, 09:55 AM
  5. Goodridge brake lines
    Last Post: 08-09-05, 10:42 AM
