Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
Thread: Scratchy Drive Noise?
    BobA's Avatar
    BobA is offline xRv PiMp ;-)
    Sussex Riviera
    Re: Scratchy Drive Noise?
    Stumpy' is thinking along the right lines I think.
    I'd suggest checking the following.
    If you have a pattern front sprocket MAKE SURE it is fitted the correct way round. If it is not, the front and rear sprockets will be slightly out of line and there will be a sideways force on the chain causing it not to mesh correctly with the front sprocket.
    Remove the sprocket cover, put the gearshift back on, and ride the bike with the cover off. See if this makes any difference. If my chain is too slack, there is a noise on decelation where the bottom of chain rubs along a raised tab moulded into the cover.
    Check the sprocket retainer for wear.
    Check the chain guides on the swingarm for wear or dirt.
    Good Luck
    digitalcaptive's Avatar
    Apr 2008
    Have you checked the movement of the front sprocket?
    Is it an OEM or after market?
    If it is an after market spend a few pennies on an OEM front sprocket and see if that removes the noise.
    No its definately and OEM
    Good Luck
    Thanks Bob, a few jobs for the weekend me thinks
    I'm on the Safe House List
  4. #13
    Grooverider is offline Senior Member
    Sep 2006
    Essex
    I'd be amazed if it is this, but I sometimes get what could be described as a scratchy noise on acceleration. It appears around mid revs but passes fairly quickly. After a few head scratches, I worked out that the bash plate was just touching the frame and the vibrations made it rattle.
    Like I say, probably a mile off but thought I'd throw it out there !.
    Good luck.
    Paul
  5. #14
    Wigan Chris's Avatar
    Wigan Chris is offline Senior Member
    Jan 2008
    Wigan
    ... "spend a few pennies on an OEM front sprocket ...
    now thats just going to make a mess of his garage floor ...
    ill get me coat ...
    Chris.
    _____________________________
  6. #15
    Quote Originally Posted by Wigan Chris View Post
    ill get me coat ...
    At least he wont slip over on it.
  1. noise
    By ton304 in forum Transalp
    Last Post: 31-05-11, 10:59 PM
  2. Wot a beautiful noise!
    By RobRus in forum Aprilia
    Last Post: 26-04-09, 02:07 PM
  3. 250 Engine noise
    By BIG Baz in forum XR
    Last Post: 17-03-09, 11:17 PM
  4. AT Advise - Noise when run for a while..
    By African Simba in forum Africa Twin
    Last Post: 02-05-08, 06:56 PM
  5. ticking noise
    Last Post: 20-08-07, 08:30 AM
