Results 1 to 7 of 7
Thread: Can oil cause vibrations?
    Devilkin is offline Junior Member
    Jul 2008
    South Africa
    I've been struggling with a vibration on my bike for quite a while now and i have looked at pretty much everything except taking the engine apart. Carbs have been synced, plugs checked and so on. The vibes become noticeable at bout 4000rpm
    The vibrations started a few days after I did a oil change. Also did the oil and petrol filter. Oil used was Delo 400 multigrade. The bike ran super sweet again like it normally does after a oil change. Then a few days later i started to notice the vibes.
    Could it be something with the oil or the filter? I cant imagine an oil change actually causing this but i am running out of options.
    Another strange thing happend this weekend. Had a nice long drive and noticed that the vibrations are now not as bad as they were the last 2 months, and they were quite bad. But they are still there
    Did something just randomly fall into place or something inside the engine?
    Zanzibar's Avatar
    Zanzibar is offline Member
    Feb 2009
    European Union
    Re: Can oil cause vibrations?
    Interesting. I recently did an oil change on my 105,000 mile AT. It always had a vibey clutch rattle, and a buzzy vibe at 4000rpm. Since the oil change, this is more noticeable. It was semisynth oil with JASO numbers etc, but not my usual Halfords semi.
    Curious to see if people can shed light on this. I may change the oil and see if it's better.
    Have you tried Flushing oil?
    Clean the system out then fill with the good stuff.
    Zanzibar's Avatar
    Feb 2009
    European Union
    Engine was well flushed, in my case.
    Quote Originally Posted by Zanzibar View Post
    Try adjusting the tickover, sometimes when the oil is changed the engine idles differently, adjustment of tickover can sometimes remove the vibrations. Also check the coolant level.
    Zanzibar's Avatar
    Feb 2009
    European Union
    Thanks - coolant and tickover correct. It must be the oil, but with the right specs it should make no difference.
    Jul 2008
    South Africa
    I'm glad to see that im not alone with this strange problem. I'm going to change my oil this weekend and will post an update on the problem
  1. Vibrations??
    By Scooter in forum Africa Twin
    Last Post: 25-06-09, 02:53 PM
  2. Vibrations
    By Wigan Chris in forum Africa Twin
    Last Post: 29-09-08, 04:30 PM
  3. Vibrations
    By transalper in forum Transalp
    Last Post: 31-03-08, 08:57 PM
  4. engine vibrations
    By Phoenix in forum Africa Twin
    Last Post: 16-08-06, 04:47 PM
  5. Good Vibrations
    Last Post: 10-04-06, 12:20 PM
