Results 1 to 4 of 4
Thread: Replacement engine RD07/97 model - RD04/92 model
    skyivica is offline Junior Member
    Feb 2008
    Stip, Macedonia
    My question is : How much differences between the engine RD07/97 model and RD04/92 model?
    I wanted a change engine.
    Thanks for helping.
    Skyivica, Macedonia
    BobA's Avatar
    BobA is offline xRv PiMp ;-)
    Sussex Riviera
    Re: Replacement engine RD07/97 model - RD04/92 model
    Which model AT do you own?
    The main difference between the RD04 and RD07 engines is that the 07 has a (TPS) Throttle Position Sensor, different carburretors, and a different ECU.
    Hopefully someone else can give you a definite answer.
    Feb 2008
    Stip, Macedonia
    I have AT RD04/92 !
    Thanks for help
    Lord Stig's Avatar
    May 2004
    West Lothian
    There's also an issue with the ignition pick up from the flywheel - that could be more of a problem than the ancilliaries. The ignition circuit after the engine proper is also different (e.g., twin coils per cylinder on the RD04), but (like the non-TPS carbs) that should be possible to bodge using your existing components.
  1. What model
    By yamtz250 in forum XR
    Last Post: 13-07-09, 07:38 PM
  2. What model
    By yamtz250 in forum XL
    Last Post: 01-05-09, 12:33 PM
  3. will 2003 model tank fit a model 2000 bike?
    By marc lenssen in forum Varadero
    Last Post: 13-04-09, 11:40 AM
  4. rd04 engine in a rd07 frame ??
    Last Post: 03-03-06, 05:46 PM
  5. Will an RD07 engine fit an RD04
    Last Post: 06-09-04, 04:47 PM
