Results 1 to 10 of 12
Thread: speedo malfunction
    Whealie's Avatar
    Whealie is online now Wing Commander
    Lewisham, SE London
    speedo malfunction
    Any ideas - it juddered and then almost died, recording about half the actual speed.
    If it had stopped altogether I'd have suspected a broken cable.
    BobA's Avatar
    BobA is offline xRv PiMp ;-)
    Sussex Riviera
    Re: speedo malfunction
    I'd guess it might be the nylon gear in the drive unit. It's either worn or seizing up with old grease. Could be the cable, but I doubt it.
    Check the clocks by swapping them over between your two AT's
    Have you had the front wheel out recently? Bent tabs on the metal drive plate in the front wheel can cause the speedo to run erratically.
    Mabels Old Man's Avatar
    May 2006
    The Dark Side
    Not an option when he's halfway to Scotland
    1995 Fireblade Urban Tiger
    2009 BMW R1200GSA
    Events Manager GS Club
    BobA's Avatar
    Sussex Riviera
    Quote Originally Posted by Mabels Old Man View Post
    That bloke is half way to somewhere, but I didn't think it was Scotland!!!!!
    In that case, I guess he is farked, unless he gets up really early tomorrow morning and obtains his spares from the hotel car park, where I'm sure there will be a shedload of donor bikes!
    Bon Voyage and Good Luck you lot!
    vinas's Avatar
    vinas is offline Junior
    Feb 2009
    Éireann Green country
    Yes Whealie BobA spot on, me to have same problem, just like that out of blue speedo start jumping and then died. Turned out to be nylon gear seized with old grease, so wheel has to come off and good clean inside some fresh lube (grease) and like new…If leave for to long could damage nylon gear and will set you back €19 + p&p there is link gear spdmt honda
    Val
    AlanH's Avatar
    Bristol, UK
    Chris, give me a shout when you're back. I have a spare speedo gearbox.
    Whealie's Avatar
    Lewisham, SE London
    Cheer guys, My initial suspicion is with Yen as I did the wheel bearings, fork oil and head races, but it can all come off for a clean. I like this solution as it also involves the least amount of work.
    But after four days sat on the bike I am in no rush even to go for test ride so it may be much later this week before I venture out into the garage.
    From Soho's I made the Lakes, the Hardknott, Edinburgh, Belfast, Dublin and London. According to my milometre I have done about 125 miles.
    dirtyden's Avatar
    dirtyden is offline Senior Member
    Jun 2006
    London
    Again same problem. Mine had new front tyre on thursday , so will check for bent tabs .
    My tripmeter reigistered 5.3miles for TLD.
    Have already replaced gearing once , hoping a good clean , straightening of tab will fix with out having to buy new.
    It had me confused as hell when it happened to me.
    I have a large collection of spares so I firstly tried a spare cable, still weird speedo readings.
    Then I swapped to a new speedo drive, no cure.
    Then I put a different set of clocks on, still the same problem.
    The tabs in the hub looked fine, it was only when I compared it to my other front wheel I could see the difference, I must have squashed them a little after putting the speedo drive in in an incorrect position.
  1. speedo
    By bluecfc in forum XR
    Last Post: 20-01-09, 02:57 PM
  2. Speedo for xr 400
    By jteale123 in forum XR
    Last Post: 02-05-08, 05:07 PM
  3. speedo help
    By jabba in forum Mechanical Advice
    Last Post: 08-03-08, 10:17 AM
  4. KM Speedo
    By jamie in forum Transalp
    Last Post: 05-12-06, 05:12 PM
  5. Speedo.
    By old red eyes in forum Africa Twin
    Last Post: 22-02-05, 03:07 PM
