Results 1 to 6 of 6
Thread: HEL Stainless Brake Lines - Bargain
    angelo's Avatar
    Apr 2006
    West Wales
    Hi Guys and GAls
    Check out these - just bought a set and while not advertised as HEL - They most certainly are and are branded etc and come complete new in the pack etc - this is a bargain. £39.99 for 2 front lines complete with Stainless ends, bangos and washers. And a really good guy to deal with.
    http://stores.shop.ebay.co.uk/EAST-MIDS-SPEED-SHOP
    Wangit's Avatar
    Wangit is offline Tea boy
    Oct 2008
    Mid Wales on the borders
    Re: HEL Stainless Brake Lines - Bargain
    Hi, great stuff. I have seen these before but of corse no idea of quality, you took the plunge and have given me the green light. What colour did you go for.Cheers
    jasonbc's Avatar
    Camborne, Cornwall
    Quote Originally Posted by angelo View Post
    Hi Guys and GAls
    eBay UK Shop - EAST MIDS SPEED SHOP: SUZUKI BRAKE LINES, HONDA BRAKE LINES, YAMAHA BRAKE LINES
    Doesn't matter which ones you get as Hel, Goodridge and Earls are all made on the same estate in Exeter in factories opposite each other and share components get the cheapest ones
    GASGAS TXT250 PRO 2006
    angelo's Avatar
    Apr 2006
    West Wales
    Quote Originally Posted by Wangit View Post
    hi I just got plain old stainless steel with clear coverand stainless steel ends - I like that look - purposeful and just flash enough
    you won't be disappointed
    Mervinh's Avatar
    Mervinh is online now Stone Crazy
    Nov 2006
    The dark side of Dartmoor
    Quote Originally Posted by jasonbc View Post
    Jase
    sorry to contradict ya mate but, Goodridge is at exeter airport, HEL at Teburn some 10 miles or more apart not sure about earls, but hel are the best deal come with stainless ends/banjo bolts as standard, add the cost of stainless ends/banjo bolts too goodridge ones and they are more expensive
    Merv
    angelo's Avatar
    Apr 2006
    West Wales
    Well I fitted them this afternoon - easy fit as long as you take time to work out which one goes on which side. I used the original guides on the forks and the original rubber inserts in then ( slit them with a razor to remove them and then slipped them over new hoses)
    all bangos were supplied stainless with lots of copper washers.
    Bleeding was a doddle and finally locked brake on with a cable tie for a few hours. The difference is huge - now I have a good brake lever with no spogyness. Braking seems better. They look great and a lot simpler than the standard ones.
    Highly recommended
    Angelo
  1. Wanted: SLR/ Dommie stainless brake lines
    By Mervinh in forum For Sale / Wanted
    Last Post: 26-12-08, 09:26 AM
  2. HEL Brake Lines
    By Lutin in forum Transalp
    Last Post: 23-04-08, 02:56 PM
  3. Stainless brake lines....
    By ger in forum Transalp
    Last Post: 14-09-06, 06:52 PM
  4. Stainless Brake Lines
    By mal in forum Africa Twin
    Last Post: 21-02-05, 11:27 AM
