Well amongst all the other jobs of recommissioning a AT that has stood in the garden for three years unstarted is a leaking water pump
Prior to test starting her ( fresh petrol/ carbs cleaned/ car battery on jump leads.)
I checked the water levels ( non existant!)
I put fresh water in and found the system was EMPTY
The reason became obvious, the water is P***ing out of the overflow on the water pump.
Theres no oil leaking/ theres no water in the oil
Its an RD07a model
Is is possible to fit a new seal ( water) to the pump?
Cheers all
PS: I still haven't started the beast, If it sounds really rough I shall make a decision on restoring or Breaking the AT
Dooh
unhappy Magwa![]()
