Results 1 to 5 of 5
Thread: Attempted theft - ignition barrel and handlebar clamps need replacing. Yen?
    sjk6000 is offline sjk1000
    Sep 2006
    uk
    Hi all
    Idiots had a go at my bike AGAIN last night. Since they stuffed up my immobiliser not so long ago, that I had to strip from the bike, they've gone and f*#ked up the steering lock and ignition barrel now by trying to force the handlebars.
    So, firstly I need an ignition barrel. Yen, you mentioned you got a CBR 600 FM-FW 91-98 ignition barrel from patternparts.net. There's also an xrv750 L-Y 90-03 barrel in the list... here. I assume they didn't have this when you got yours? Also, does this replace the steering lock pin that I'm guessing they've also damaged (if that's how it works).
    Secondly I need to replace the handlebar clamps. They've bent the stem of the right clamp when twisting the bars. Is it all one piece that goes down through the top yoke or are the clamp and its stem separate? I've a feeling they're not original so has anyone got a pair they can sell me? It's an RD07 '97.
    I've contacted the breaker at allbike in norfolk (...not allbikes up north) to see what he can do. Any help on this would be much appreciated. If anyone wants to take shifts sitting in the carpark each weekend until they come back to help me beat them stupid, do drop me a line.
    Thanks all, Steve
    vinas's Avatar
    vinas is offline Junior
    Feb 2009
    Éireann Green country
    Re: Attempted theft - ignition barrel and handlebar clamps need replacing. Yen?
    Quote Originally Posted by sjk6000 View Post
    Hi all
    Idiots had a go at my bike AGAIN last night. Since they stuffed up my immobiliser not so long ago, that I had to strip from the bike, they've gone Steve
    Hi Steve!
    I found this on German e-bay – RD7 ignition barrel brand new with 2 keys €30 and they accept pay pal postage to UK €9 there is link HONDA XRV 750 AFRICA TWIN VF VT Main switch Zündschloss bei eBay.de: Markenspezifische Teile (endet 11.07.09 14:35:56 MESZ)
    I hope this help Val
    That's correct, they didn't have exactly the same barrel when I wanted one, so they probably have got the right one now. The steering lock pin IS part of the new ignition switch as you suspect.
    Re the handlebar clamp being out of line. Try just loosening them all off and retightenting, this sorted mine once, I think the rubbers just distort sometimes.
    lootch67's Avatar
    South Ockendon, Essex
    Quote Originally Posted by vinas View Post
    Hi Steve!
    That's a good price! I paid £35 a couple of years ago when mine was busted.
    Sep 2006
    uk
    Hi All
    Just wanted to say thanks for your help getting the ignition barrel sorted. Ended up buying the one from PatternParts.net. The only problem, as I think you mentioned elsewhere Yen, is that the connector's are different. I had to use the kitchen scissors (shhhh) to push the wire's spades out of the new connector and put them into the existing one.
    A real bonus is that I now own the biggest spanner on the planet (30mm) for the yoke top nut (and also for the fuel tap which was my other job). I wear the trousers.
    Thanks again for your help
    Steve
  1. Ignition Barrel Problem
    By chris1201 in forum Transalp
    Last Post: 03-06-09, 10:45 AM
  2. Help swopping the Ignition Barrel.
    By shack in forum Africa Twin
    Last Post: 11-07-07, 10:38 AM
  3. Ignition Barrel
    By gibbo in forum Africa Twin
    Last Post: 25-03-07, 09:08 PM
  4. Attempted Theft
    By adhwales in forum Africa Twin
    Last Post: 08-03-07, 03:11 PM
  5. Ignition Barrel
    By miggy in forum Africa Twin
    Last Post: 28-07-06, 02:40 PM
