Results 1 to 10 of 11
Thread: how strong?
    super@ Guest
    how strong?
    Got a new seat cover from wemoto cos mine is spliting. Question is how strong does the staple gun have to be to get the staples into the plastic. The local hardware store has one starting at 10 euros but the next one up is 42€. will the 10 euro one be enough is it the staples that need to be strong or the gun putting them in
    42€ seems like a lot for something I will never use again
    Lumiya's Avatar
    Ziost
    Re: how strong?
    Bought an air Staple/Brad gun at weekend in Aldi should do brilliant with 10mm staples...
    Jen did try it though on an XTZ750 seat using a hand press staple gun (cheap £10 one) and the staples either didn't penetrate enough or bent..
    When I had my seat done a local upholsterer did it including better foam padding for £20.. I just supplied him with my cover (bought from M&P)
    super@ Guest
    Re: how strong?
    I live in Spain so dont have those options to hand.
    I did find this on amazon though, do you think it would do the job?
    Silverline 868555 10-14 mm Heavy Duty Steel Staple Gun: Amazon.co.uk: DIY & Tools
    or would this be better
    http://www.amazon.co.uk/230V-Electri...761823&sr=8-26
    Lumiya's Avatar
    Ziost
    Re: how strong?
    The electric/air staplers will always be better, they tend to be a lot stronger, will take larger staples and sometimes are also variable..
    The first stapler I would avoid, it's the same one as Jen originally tried..
    You can also get hammer staplers that you hit the head of with a rubber mallet, they might be cheaper than getting an electric/air stapler
    Snaphappy's Avatar
    Mar 2008
    ExPat in Germany
    Re: how strong?
    Just check the thickness of the staples some are too thin and will buckle before they get in the plastic I bought a cheapish gun just for my seat uses 6mm staples with 1,3mm gauge
    Rapid E-Tac
    Mervinh's Avatar
    Nov 2006
    The dark side of Dartmoor
    Re: how strong?
    and hold the stapler down flat and hard on the surface that you are trying to staple with a hand stapler, if it is not held down or a bit off the surface the staples will not go in , the stapkle will push the gun back up
    merv
    Traveller's Avatar
    Traveller is offline Senior Member
    Nov 2008
    Derby
    Re: how strong?
    I have used the hand held basic stapler for similar things. Repairing caravans where the staple has to pass through thin aluminium sheet and into wood. I found that the staple wouldn`t go fully home but I used a tack hammer to finish them off. OK for a one off job.
    I also used it to sucessfully make/cover a seat on a suzuki 250 trail bike. (TS 250 two stroke?). I made a plywood base took the foam out of a three piece suite and bought a replacement seat cover.
    These staple guns are used a lot for craft work so you may be able to borrow one and give it a try.
    RWB XRV 750
    Red XRV 750
    GL 1800
    Yellow Honda CT90 Trail
    Red Honda CT90 Trail
    Horses for courses
    todd5774 is offline Senior Member
    Oct 2008
    midhurst
    Re: how strong?
    If you are having a problem with the staples going into the plastic base then gently heat up the plastic with a heatgun, they will go in fine then as it cools will grip the staple, Heat a small section at a time.
    Lord Stig's Avatar
    May 2004
    West Lothian
    Re: how strong?
    Another method is to use flange- or pan-head self tappers. That's how I normally do it.
    Sully22252 is offline Senior Member
    Sep 2008
    Cornwall
    Re: how strong?
    I fitted a Wemoto cover to an AT seat base at the weekend using a handheld staple gun just like the one pictured and had absolutely no problem. You just have to make sure the staples are man enough for the job, the staple gun is easily strong enough, as long as you make sure the material is pressed hard against the plastic when you fire the staple.
    One thing which is really worth doing is to fit and stretch the cover properly over the seat base and leave it for a couple of days before you staple it, just to give time for the creases to come out and also to let the material stretch.
  1. The Force was even too strong for.......
    Last Post: 31-01-09, 01:29 AM
  2. How strong is kevlar-Jenna/Kymmy
    By Xander in forum Mechanical Advice
    Last Post: 26-06-07, 09:44 PM
  3. Replies: 11
    Last Post: 15-01-07, 10:24 PM
  4. HELP You need a strong right hand grip for this !!!
    By Phoenix in forum Africa Twin
    Last Post: 22-09-06, 11:10 AM
