Results 1 to 5 of 5
Thread: Tripmaster
    c13tay's Avatar
    c13tay is offline Senior Member
    Standish, Lancs
    Tripmaster
    How easy is it and what is involved in fitting a tripmaster to an RD04 ?
    Anyone done it ?
    Chris
    BobA's Avatar
    BobA is offline xRv PiMp ;-)
    Sussex Riviera
    Re: Tripmaster
    It could be done with a little electrical knowledge and a truckload of money.
    Not done it, but you will probably need...
    • To buy a good working Tripmaster in the first place.
    • To modify the wiring loom.
    • To buy and fit new clocks, as they are smaller diameter and the speedo contains the sender for the Tripmaster.
    • To buy and install a suitable front subframe to hold it above the clocks.
    • To possibly buy and install a new front fairing if it doesn't all fit underneath.
    Not that easy really!
    You could always just buy and add a supplementary computer like a Trailtech Vapor HERE
    Good Luck
    AlanH's Avatar
    Bristol, UK
    Re: Tripmaster
    Seconded on the Trailtech Vapour. That's the cheapest option and gives far more info than the tripmaster anyway.
    As BobA says, you'll need to source parts from the XRV750N - the last RD04 model. The clocks are an all-in-one unit so it's not just a matter of replacing the speedo. You will need the subframe too but the fairing cowl is the same. As the XRV750N only ran for a year, these parts are scarce used and cost an arm and a leg new.
    AlanH's Avatar
    Bristol, UK
    Re: Tripmaster
    I think it's time we both got our Avatar pics up to date Chris
    c13tay's Avatar
    Standish, Lancs
    Re: Tripmaster
    I think you are right Alan !!!!
    Wont bother witht the Honda tripmaster then but the other thing looks interesting.
    Came the long way to work on the bike this morning - huge grin on my face when i got here !!
  1. Tripmaster on RD 04?
    By andras in forum Africa Twin
    Last Post: 13-01-09, 07:15 PM
  2. Tripmaster......... again!!
    By g45her in forum Africa Twin
    Last Post: 02-01-09, 05:13 PM
  3. Tripmaster Mod
    By Wigan Chris in forum Africa Twin
    Last Post: 25-11-08, 07:27 AM
  4. Tripmaster... again
    By ddcristi in forum Africa Twin
    Last Post: 31-07-08, 10:01 PM
  5. Tripmaster problem
    By dery in forum Africa Twin
    Last Post: 27-07-08, 05:00 PM
