Results 1 to 2 of 2
Thread: Mystery fuel line
    matt Guest
    Mystery fuel line
    Ideas anyone?
    OK, been battling with tappets and have found a fuel line that goes nowhere. I've checked to see if there are any disconnections and also onto the (removed) fuel tank. No clues there.
    It connects near the rear shock with a T to the fuel lines coming from the bottom of the carbs, which I believe are the float bleed valves. It them connects to the breather that runs out the bottom of the bike.
    I'm guessing this is a breather pipe, but can't find any reference to it in the Haynes manual, and putting it there seems a bit wierd.
    In the picture, the yellow tooth brush handle is pointing at it. It ends about 5cm in between the carbs, open ended
    African Simba is offline Senior Member
    NW - UK
    Re: Mystery fuel line
    I think its a breather pipe. I may be able to look at mine this evening and let you know -
  1. Oh no! a mystery elec. fault again!
    By Zanzibar in forum Africa Twin
    Last Post: 02-05-09, 08:48 AM
  2. mystery burning niff !!
    By ADE THE BLADE in forum Transalp
    Last Post: 27-04-09, 04:59 PM
  3. Fuel line problem.
    By doglegdon in forum Africa Twin
    Last Post: 19-05-08, 07:02 AM
  4. The mystery bike
    By kiroh in forum Chatter
    Last Post: 20-04-07, 04:01 PM
  5. The TKC80 mystery
    By boboneleg in forum Chatter
    Last Post: 01-08-06, 06:27 AM
