Page 2 of 2 FirstFirst 1 2
Results 11 to 12 of 12
Thread: Very elecrically weird
    Zanzibar's Avatar
    Zanzibar is offline Member
    Feb 2009
    European Union
    Re: Very elecrically weird
    Braw, lairdie Stig! all info noted and taken on board. I hope it also helps others as our ageing ATs clock up the miles......
    brko's Avatar
    brko is offline Member
    Surrey
    hi
    maybe you've got short somewhere. it was happening to me when my starter relay got burnt by dying rectifier. check the rectifier, make sure it is charging ok.
    check the earth terminals and battery connections. look at the 30amp fuse inside the starter realy, close to red positive wire from the battery, try moving it around a bit to see if it will cut out. it could be just coroded earth too.
    good luck
  1. weird??
    By veodoble in forum Comments & Suggestions
    Last Post: 20-02-09, 02:19 AM
  2. Most weird advert currently on TV
    By Lumiya in forum Chatter
    Last Post: 01-02-09, 06:12 PM
  3. Weird Stag Do???
    By Oly in forum Past Charity Events
    Last Post: 26-02-08, 05:40 PM
  4. Weird CD's
    By alpslapper in forum Chatter
    Last Post: 26-01-08, 09:30 PM
  5. weird day yesterday
    By Shep in forum Africa Twin
    Last Post: 28-08-06, 08:07 PM
