Results 1 to 10 of 13
Thread: changing gear
    kevsky's Avatar
    kevsky is offline Member
    Sep 2008
    durham
    changing gear
    injured my left thumb and finding it hard to ghange gear.absolute agony sometimes.coming back from work today in the pi**in rain and was just letting throttle off and changing without using clutch...is this ok to do or can it cause untold damage...any advise would be helpfull....thanks ... kevsky...
    Re: changing gear
    I sometimes do the changes without the clutch and have had no problems.
    Although it may cause the chain to stretch quicker.
    winxp-master's Avatar
    Jan 2008
    Redcar
    Re: changing gear
    I'm no technial wizard by any means so i have to use common sense so what i would say is, if you didn't need to use the clutch then why is it there?
    Lumiya's Avatar
    Ziost
    Re: changing gear
    There's a few main dangers
    1# you'll lose control/traction especially on slippery surfaces as the tension on the drive suddenly changes
    2# you'll strip the clutch and/or break the chain due to the same forces causing #1
    3# You could chip the teeth off the gears/dogs as you won;t give the gearbox time to synchronize
    Mervinh's Avatar
    Mervinh is online now Stone Crazy
    Nov 2006
    The dark side of Dartmoor
    Re: changing gear
    balance the revs correctly get a smooth change and it will not do too much harm, lots of people do clutchless changes, especially useful if your clutch cable is dodgy,
    Jan 2008
    Redcar
    Re: changing gear
    Quote Originally Posted by Mervinh View Post
    Fix the cable, do the correct gear change
    angelo's Avatar
    Apr 2006
    West Wales
    Re: changing gear
    If you are going to have long term problems fit a racing quick shifter - it works on the gear lever - as you start to lift it kills the engine an so no load snick into gear and when you release on comes the engine - most racers use them for up shifts - big buck though!
    grazie is offline Senior Member
    Jun 2007
    North London
    Re: changing gear
    Adjusting clutch so biting point is closer.
    Rest hand on bars and not grip.
    Pull off in second and go up and down two gears using full rev range.
    Lend a Cub C90.
    Don't ride if you can't focus due to pain.
    Clutchless up changes better then down ones.
    erm.......
    Africa Twin RD03
    Mervinh's Avatar
    Nov 2006
    Re: changing gear
    Quote Originally Posted by winxp-master View Post
    only as a get ya home i mean
    Jan 2008
    Redcar
    Re: changing gear
    ahh i'll let you off then
  1. I'm thinking of changing
    Last Post: 27-03-08, 02:15 PM
  2. Changing oil
    By HelmetHair in forum Africa Twin
    Last Post: 12-06-07, 10:35 PM
  3. changing oil
    By sa6andy in forum Africa Twin
    Last Post: 20-03-06, 10:53 PM
  4. Changing sparkplugs.
    By Fatjohn in forum Transalp
    Last Post: 01-10-05, 08:03 PM
  5. when changing down gear i have to pull in cluth 2nd time
    Last Post: 02-07-05, 01:04 AM
