Results 1 to 8 of 8
Thread: how do i test the amperes going through the reg/rec?
    yoashman is offline Member
    Apr 2009
    Scootlund
    Hey, Iv said it once and I will say it again! How do i test the amperes going through the reg/rec? I found them new for £70, but I dont want to spend out that much if its not goosed! Cheers alot.
    Shox Dr is offline Senior Member
    Jul 2009
    East Yorks
    Re: how do i test the amperes going through the reg/rec?
    before you go and spend 70quid. I've just found this thread, suggesting that R1/R6 fit.
    As there are more of those bikes around you'll be albe to pick one up cheaper
    russt1969's Avatar
    russt1969 is offline Long Way Home 2010
    Aug 2008
    Cheam, Surrey.
    They do. I fitted one after my r/r went on me. Got it off ebay for £25.00.
    Apr 2009
    Scootlund
    Sweet! Gonna buy one of these. But first...my bike is the 1995 RD07, do you know if I have to get a particular year of r1 regulator/rectifier? And will it just plug right in, or will I have to make some changes? Cheers alot
    russt1969's Avatar
    Aug 2008
    Cheam, Surrey.
    Wont fit straight on. You have to modify the wiring. The Honda one has 7 pins where the Yammy has 5. Not a problem. Let me have your email and I'll send you some info via that. Or search the site. There's something on here somewhere.
    Russ
    Apr 2009
    Scootlund
    Hey, cheers for all the info so far on the reg/rec. If you could forward me that info that would be great, my email is XXXXXXXXXXXXXXXXXX . Looking to get it sorted asap as I used my bike every day for work and gotta get it sorted! Cheers alot! Ash
    russt1969's Avatar
    Aug 2008
    Cheam, Surrey.
    All done Ash. Email sent and also found this YAMAHA R1 YZF 1000 R1 4XV 98/99 REGULATOR RECTIFIER on eBay (end time 23-Aug-09 16:52:31 BST)
    Edit your post with your email add in and get rid of it so you don't get any spam......
    Russ
    Merkado is offline Member
    May 2008
    Isarel
  1. Test
    By Sharrie test user in forum Problems with the forum?
    Last Post: 28-09-08, 09:40 PM
  2. Motorbike test - Check, Car test - Check
    By Palmer in forum Chatter
    Last Post: 22-07-08, 06:50 PM
  3. test
    By Chad in forum Chatter
    Last Post: 08-04-06, 01:47 PM
