Page 3 of 3 FirstFirst 1 2 3
Results 21 to 27 of 27
Thread: Down-jetting for fuel economy
  1. #21
    scarfacehugo's Avatar
    Jul 2008
    London
    Re: Down-jetting for fuel economy
    [QUOTE=Lord Stig;406600]... I get over 60 mpg on 15/46 final reduction, and even with the differing jets and TPS of the later RD07a I wouldn't have thought there would be a difference that great.[QUOTE]
    And yours is a RD07A...?
    trophydave's Avatar
    trophydave is offline Senior Member
    Feb 2007
    Nottingham
    [QUOTE=scarfacehugo;406727And yours is a RD07A...?[/QUOTE]
    Mine is.I have only had it a couple of weeks,the first tankful gave 48mpg.It's on 16/45 gearing and is fitted with a Remus can with a baffle in it.
    I would hope for a bit more on a long run.
    Last edited by trophydave; 19-10-09 at 08:44 PM. Reason: Can't read the number of teeth on my sprocket
    Rust never sleeps
  4. #23
    Lord Stig's Avatar
    May 2004
    West Lothian
    It is indeed - 2001 in fact, with almost 95,000 mile on it. Even with that the thing is blisteringly quick up to the red line (shame that's a shade over 100, but at least I can reach it even against a heavy Scottish headwind, which the standard gearing would struggle to do, let alone raised gearing). Obviously "blisteringly" is relative...
    I've been hareing around the last week (again relative - no faster that 90 mph) but today I filled to the brim with 16 litres and did 198. That's still approximately 55 mpg. Some others on the thread I started (see here) are doing far better with higher gearing (up to 70 mpg if I recall). Something is wrong with yours, but what?
  5. #24
    antti's Avatar
    antti is offline Senior Member
    Aug 2008
    Southern Finland
    About down jetting,
    I did check my plugs and they indicate that my bike is running rich, jetting is original 118/120. So I ordered smaller mains, pair of 115`s and pair of 112,5`s.
    I think that someone has told that his Twin is going fine with even 107 mains, is that only BS?
    I started to think that is it even worth for to try those 112,5`s??
    Maybe I`ll try 112,5 front and 115 rear.
    G/S project bike.
  6. #25
    jasonbc's Avatar
    Camborne, Cornwall
    Quote Originally Posted by Sully22252 View Post
    I dont know how far down you plan on going in Africa, and if you've been there before then I'm sure you know all this, but once you get South of Western Sahara, into Mauritania and on into Mali, Senegal etc, bear in mind you will be running on crap low octane fuel.
    I've been down there a few times on different bikes and have always used the standard setup without problems, but last year one of our group on a Yam had added an aftermarket can, and also dynojet filter and re-jetted to suit. It ran fine until we reached Mauritania but from the first fill up would not run for more than 30 seconds on the low octane fuel available. Once it was back in Western Sahara (or Moroccan Sahara as the Moroccans call it) on 93 octane or above it was fine again.
    The lowest I know I've used in an AT was 85 octane and it ran fine on stock exhaust, filter and jetting.
    Did you do the trip with louise Hillier and gary Prisk??
    GASGAS TXT250 PRO 2006
  7. #26
    antti's Avatar
    Aug 2008
    Southern Finland
    Quote Originally Posted by antti View Post
    About down jetting,
    I have now driven about 4500 km with 112,5 main in front and 115 rear.
    I think it works generaly better and consumption dropped over half a litre for 100 km.
    G/S project bike.
  8. #27
    antti's Avatar
    Aug 2008
    Southern Finland
    Is it really an option to go even smaller mains?
    I did check plug from front and it was dark, almost black.
    Carbs are in balance, choke is defenetly working.
    Airfilter has been taken care.
    Plugs have been in use for about 4500 km.
    It seems that bike goes to dyno next winter.
    G/S project bike.
  1. Fuel economy
    By 1965paulh in forum Varadero
    Last Post: 20-04-09, 10:44 PM
  2. yet more fuel economy questions
    By juscrooky in forum Dominator / FMX
    Last Post: 25-11-08, 10:27 AM
  3. Fuel economy revisited
    By 24ftlb in forum Transalp
    Last Post: 17-04-07, 04:16 PM
  4. what fuel economy can i expect.
    By mitch in forum Transalp
    Last Post: 17-09-06, 09:10 PM
  5. fuel economy
    Last Post: 05-10-04, 09:08 PM
