Results 1 to 3 of 3
Thread: Master Cylinder prob
    super@ Guest
    Hi, I have replaced my brake lines and discs and went for a ride and when I got back i noticed that fluid is spilling out of the master cylinder from the top.
    is this because I have over filled or do i need a new lid and gubbins for it
    Cheers once again.
    Ps put kyoto wavy discs on and they look well smart
    Re: Master Cylinder prob
    You could have over filled it, or you could have an air lock.
    Leave it with the lever applied, overnight, then see if you need to remove or add fluid.
    scarfacehugo's Avatar
    Jul 2008
    London
    Too much fluid can cause pressure on the pads, causing them to rub against the discs all the time. Hot pads, hot oil, oil expands, creates more pressure on the pads untill the pads lock on to the discs. Beware.
  1. Brake Master cylinder
    By flipfly in forum Transalp
    Last Post: 02-12-08, 09:48 PM
  2. master cylinder bleed screw
    By moon in forum Transalp
    Last Post: 31-08-08, 10:55 AM
  3. Brake Master cylinder cover
    By R0vers in forum Bodgers Corner
    Last Post: 30-07-08, 11:45 AM
  4. Front brake master cylinder
    By Ratrap in forum Transalp
    Last Post: 15-07-07, 11:45 PM
  5. Replacing the master cylinder
    By Namibia in forum Africa Twin
    Last Post: 04-06-07, 10:31 AM
