Page 2 of 19 FirstFirst 1 2 3 4 12 ... LastLast
Results 11 to 20 of 186
Thread: Stripping and Rebuilding Do & Do not
    Wingnut's Avatar
    Wingnut is offline Senior Member
    Sep 2009
    Ireland
    Re: Stripping and Rebuilding Do & Do not
    OK this is how it used to look
    This is the first strip session.
    Having a cup pa and a fag, started at 8 this evening finished at 11.
    1. pillion passenger peg frames off both sides
    2. tank fairings off both sides
    3. Horn off plastic mesh hanging on choke cable
    4. side fairings rear both off
    5. Saddle off
    6. fairing at nose of bike off- brass collets came out of plastic molding.
    7. Exhaust off
    8. Bash plate off-rubber that allows bash plate to vibrate rotten- all allen bolts tight as hell , used power steering oil on front of bolt before twisting.
    9. chain guard off
    10. rear wheel off- being held together with hope ,its way worse than I thought.
    11. rear wheel sprocket off
    12. rear wheel break disk off
    13. rear travel box base off
    14. rear subframe off which travel box is bolted down onto
    15. break light fairing removed
    16. removing tube tyre tomorrow and removing spokes- spokes shot to **** -hope hub is clean don't think I need to get it powder coated will clean and post to CWC for rebuild .
    Now you can start putting bets as to weather I finish this or not but I'm aiming for March 2010
    Jonny
    kennymact's Avatar
    Sep 2006
    christchurch/newzealand
    go man go.....
  4. #13
    Wingnut's Avatar
    Sep 2009
    Ireland
    Kenny
    Cheers man , hope when I'm finished that it does go man go , with a few less rattles and a cleaner body.
  5. #14
    Wingnut's Avatar
    Sep 2009
    Ireland
    Lightbulb Re: Stripping and Rebuilding Do & Do not
    Ok
    Sunday morning today the 4/10/09
    Said Id like it to give it one last turn before I started dropping out the air filter . Gave the key fob a press and nothing , no beep , no lights blinking . Thought it could be the key fob. Darted into halford's , changed batteries and nothing (had reckoned on batteries cos it came with bike and from time to time gave trouble.
    So Ive decided to remove the immobilizer altogether get back to factory wiring setup .
    This is the mess Ive got to sort out
    So any advice ? Wire back to basics or try and fault find on the immobilizer.
    This is the part I was dreading and I'm getting a good dose of it with this
    immobilizer.
    This is where I'm at right now .
  6. #15
    BobA's Avatar
    BobA is offline xRv PiMp ;-)
    Sussex Riviera
    Back to basics if it was me!
    Carefully remove the alarm/immobiliser and rejoin (carefully sleeve then solder) any wires that have been broken into or spliced.
    You can always re-install it later, but at this stage of stripping, it could just add hours of pointless searching to getting the bike running. If it's like it now, it'll be ten times harder once you've put the bike back together and can't figure out why it's dead or won't start.
  7. #16
    Wingnut's Avatar
    Sep 2009
    Ireland
    I'M thinking the same remove the dame thing and get the bike back running and return to stripping .
  8. #17
    Lee Halsall is offline Senior Member
    May 2009
    Moray
    Your spot on with the alarm removal,the last thing you want is that thing giving up when your miles from anywhere.
    I managed to de alarm my last bike,I found that the wires had been cut and the unit just soldered in,wasn't too hard to re solder the wires back together,and chuck the alarm in the bin.
    I had to do the same to my old Disco ,bloody immobiliser ,grrrr.
    My old landrover and the AT have a lot in common,both weigh a ton.
    Lee
    PS Just had a thought, the alarm I took off had a microswitch under the seat,immobilised if the seat was lifted.
  9. #18
    Wingnut's Avatar
    Sep 2009
    Ireland
    Fork me if I wasn't pissed off this morning . Any way got on the Internet in the after noon and found a nugget of information "hit the alarm unit a slap" . Well went down to the shed with all the technology info and spent the afternoon trying this and trying that and at 8 this evening drinking a cup of tea and feeling a good bit forked off , I remembered the slap it suggestion . With nothing to lose I hit the forking thing a decent smack with a ring spanner and guess forking what the piece of shazit beeped and flashed and beeped and flashed to every push of the key fob. I kid you not . The chicken of happyness has returned to the shed
    And yes it coming out over the next couple of evenings and Im going to do some thing special with the piece of ****z.
    Oh happy days
  10. #19
    Wingnut's Avatar
    Sep 2009
    Ireland
    Started to strip out demoralizer tonight slow going . Hopefully Ill get it out over the weekend.
  11. #20
    ritosxf's Avatar
    ritosxf is offline sfx wheels
    Jul 2009
    walsall , well cheslyn hay to be exact , jnc11 m6
    never ever invite all your mates round to do this with a garage full of beer , lol
  1. Wheel rebuilding
    By Neil G in forum Transalp
    Last Post: 14-10-09, 09:43 PM
  2. Rebuilding wheels
    By scarfacehugo in forum Africa Twin
    Last Post: 09-09-09, 11:54 AM
  3. Stripping Story! RD02
    By Pistol_Pete in forum Dominator / FMX
    Last Post: 25-10-08, 06:17 PM
  4. Africa Twin RD04 stripping for spares.....
    By Toit_sa in forum For Sale / Wanted
    Last Post: 04-07-08, 03:11 PM
  5. stripping decals
    By Whealie in forum Mechanical Advice
    Last Post: 20-12-06, 10:29 AM
