Page 4 of 19 FirstFirst ... 2 3 4 5 6 14 ... LastLast
Results 31 to 40 of 186
Thread: Stripping and Rebuilding Do & Do not
  1. #31
    BobA's Avatar
    BobA is offline xRv PiMp ;-)
    Sussex Riviera
    Re: Stripping and Rebuilding Do & Do not
    Take the spring off the shock and get it blasted and either powdercoat it or hammerite it.
    Wingnut's Avatar
    Wingnut is offline Senior Member
    Sep 2009
    Ireland
    Out the top or out the bottom of the shock/damper?
    If I disconnect it at the top can I DIY refill the damper?
  4. #33
    Wingnut's Avatar
    Sep 2009
    Ireland
    Who covered who - Jimmy or Jonny Jones?
  5. #34
    Wingnut's Avatar
    Sep 2009
    Ireland
    Ok
    Rads = refurb .
    Rad guards held together with the paint. Neededto repair the bolt holes.
    Halfords got some of these
    Worked a treat
    Used a paint stripper / gas tourch , not great took a while to get metal up to temp.
    Then had to fix broken fan bracket rad side , opted for shelf bracket and drilled rad plate and taped in screw - making sure not to puncher rad core - tried brazing but braze would not stick to
    aluminum
    Oh yeah over flow from rad cap fell off as I was taking of the overflow pipe .
    Taped the hole and sone stainless steel tube it like the whole rad is made of paper .
    Will take pict and post.
    Ive also got a question what do you use on exhaust pipe to freshen them up?
    After some wire wool got them back to this
    Just wondering what else I can put on them to bring them back to like.
    Jonny
  6. #35
    Ysbytymike's Avatar
    Ysbytymike is offline Senior Member
    Apr 2009
    Swansea
    Like Wingnut, I too am stripping my RD04 to refurbish and re-build the engine due to past mistreatment of bike (pre owner). [see AT Butcher in this forum for details]
    Anyway, I've already got the bike down to just the frame, with everything in boxes. What I'd like to know is lots of little things like the rubber chain guide on top on the swinging arm is quite worn. Is there anywhere that still stocks this type of product.
    The other question that I'd like to have clarified is about how to take the spring off the damper. The question was asked above but the cryptic answer I couldn't understand!
    So if anybody could help here please.
    Growing old is inevitable... Growing up is optional
  7. #36
    Lutin's Avatar
    Galway
    Mike,
    It's fairly easy to track down the spares you need.
    First off, have a look at this site -
    Honda Motorbike Parts
    If you put in the VIN number, the site will respond with all the correct parts fiches for your bike. From these you can get the required part numbers which you can then put into this site -
    David Silver Spares - Search By Part Number
    Job done.
    For other, more generic spares, it is worth checking out Wemoto here -
    The UK’s biggest choice of motorcycle parts for Japanese and European machines.
    There shouldn't be too much trouble getting the spares, although the prices of some will cause an involuntary in-drawing of breath. But that's one of the joys of owning such a classic machine.
  8. #37
    Ysbytymike's Avatar
    Apr 2009
    Swansea
    Thanks very much for that Lutin.
    Been looking at the different rubber components that are going to need replacing, (hoses, carb intake, chain tensioners) and so on and wondering how difficult it was going to be to source them.
  9. #38
    grazie is offline Senior Member
    Jun 2007
    North London
    QUOTE (ysbytymike) -. What I'd like to know is lots of little things like the rubber chain guide on top on the swinging arm is quite worn.
    Mike,if you find the part number for this could you let me know as I need one for my RD03. I've had a look on the micro finch in the Tech Data section but couldn't find it.
    Cheers.
    Africa Twin RD03
  10. #39
    Ysbytymike's Avatar
    Apr 2009
    Swansea
    Not a prob..
  11. #40
    Wingnut's Avatar
    Sep 2009
    Ireland
    Quote Originally Posted by Ysbytymike View Post
    Im at work and should be on the tinternet right now but Ill be back on tonight mad to see your bike mate (forking sounds wierd) any way will have a chat later.
    Sound
    Jonny
  1. Wheel rebuilding
    By Neil G in forum Transalp
    Last Post: 14-10-09, 09:43 PM
  2. Rebuilding wheels
    By scarfacehugo in forum Africa Twin
    Last Post: 09-09-09, 11:54 AM
  3. Stripping Story! RD02
    By Pistol_Pete in forum Dominator / FMX
    Last Post: 25-10-08, 06:17 PM
  4. Africa Twin RD04 stripping for spares.....
    By Toit_sa in forum For Sale / Wanted
    Last Post: 04-07-08, 03:11 PM
  5. stripping decals
    By Whealie in forum Mechanical Advice
    Last Post: 20-12-06, 10:29 AM
