Results 1 to 10 of 11
Thread: KTM WP Forks on AT
    diskow's Avatar
    diskow is offline Member
    Slovenia
    KTM WP Forks on AT
    I have a chance to buy and I am interested in WP forks 48/60 from KTM LC4 640 SM. I presume original springs from this model are not enough for offroad use with AT... Has anybody ever use those mentioned forks on AT? Experiences? Thanks for all the answers and help.
    scarfacehugo's Avatar
    Jul 2008
    London
    Re: KTM WP Forks on AT
    Quote Originally Posted by diskow View Post
    I believe SM forks have less travel, the yokes are wider and the brake caliper stays lower than off road bikes.
    All these 3 points are not good for off road. I bet they're great forks if you dont do off road.
    BobA's Avatar
    BobA is offline xRv PiMp ;-)
    Sussex Riviera
    Check out "Garage Nights" episode 11 & 12, this will give you some ideas.
    They tried to use the SM forks for a BMW, but discovered plenty of problems.
    Ep 11: KTM forks on a BMW F650 at Garage Night
    Ep 12: KTM forks on a BMW part 2 at Garage Night
    Keep us updated on how you proceed please.
    Good Luck
    futter's Avatar
    Jul 2005
    Suffolk
    Quote Originally Posted by scarfacehugo View Post
    Depending on which forks they are the same - also the same as the 525. The calliper still sits on the top half of the disc. The standard disc is 300 mm the SM item is 320. 10mm larger is not much.
    Stormforce8's Avatar
    Stormforce8 is online now Site Admin
    Dec 2005
    New Forest - Hampshire-on-Sea
    Hi diskow
    I've just swapped out my forks for a set of WP48s from a KTM 990 Adventure.
    Here's some pics of a conversion that we did earlier this year with WP48s from a KTM 950 Adventure
    You can use pretty much any of the LC4 or LC8 forks but I would tend to agree with Scarfacehugo and BobA in that I wouldn't go for the supermoto or Duke ones as they have a shorter stroke.
    Any of the Enduro, Six Days, or Adventure models are a good swap. The only thing that requires reworking is the head stem - get a new one machined from solid bar.
    You will definitely need to uprate the springs - a good place for these is Slavens Racing - speak to Jeff.
    The brakes are easy - and if you can, just swap the whole system over with the Brembo master cylinder as well.
    If you are using a single disc conversion you can run a 320mm disc with a four pot caliper if you really want to - you'll just need to buy a caliper bracket - one of the chaps off the KTM Forum sells them on Ebay. (this is the system that we're in the process of fitting to Chad's Toxic conversion)
    Stormforce8 SmugMug gallery
    Rugged Roads
    Current stable.............
    Jul 2008
    London
    v
    Hi!
    Just one quick question. What rate springs are you using on yours?
    I've got 5.0 and they're still too soft.
    diskow's Avatar
    Slovenia
    Thanks for all the help.
    I will think about it and reconsider again before i buy anything.
    Dec 2005
    Hi!
    I basically gave the total 'wet' weight of the bike, my weight, and the type of riding I'll be doing on it to Jeff and he came back with his recommendation.
    Unless you're a little lightweight - or have enjoyed too many pies, you'll probably require between a 52 or 56 kg/mm spring for an AT
    Rugged Roads
    atgreg's Avatar
    Feb 2005
    Sydney , Australia
    Hi!
    when Iput CR250 USD's on my AT I used 0.58 springs but Im pretty heavy
    1990 RD04
    310,000km & counting
    diskow's Avatar
    Slovenia
    Let me know if that means anything more to you for an opinion if this would be ok or more?
    - Forks are WP. model 48/60. 48mm diameter/265mm extension
    - from KTM model LC 4 640 SM
    - The springs are original
    I have pictures too but i dont know how to upload it.
    extensions on regular lc4 640 is only 5 millimeter longer. Together 270mm
    Is there any disadvantage in offroad use if the yokes are wider than normal?
  1. Forks.
    By catteeclan in forum Dominator / FMX
    Last Post: 03-03-09, 08:32 AM
  2. FMX USD Forks on @?
    By nic_fast42 in forum Africa Twin
    Last Post: 15-02-08, 09:48 PM
  3. Forks new oil.....
    Last Post: 22-10-07, 03:56 PM
  4. forks
    By tuggy in forum Africa Twin
    Last Post: 08-02-06, 10:57 PM
  5. forks
    By nimrod in forum Africa Twin
    Last Post: 14-10-04, 10:06 AM
