Results 1 to 4 of 4
Thread: Pillion Step bar , pin step bar Joint
    Wingnut's Avatar
    Wingnut is offline Senior Member
    Sep 2009
    Ireland
    Title of new thread comes from the good book page 44 (XRV750 N.pdf).
    Getting components ready for powder coating . Noticed that the Pillion Step on both of the holders have rattled the the hole that the step bar joint pin goes into . OK if I get a new pin it will be to small for the hole . The rattling around has made the hole bigger . Just want to know would it be right to find a bit of rod that matches the hole on the step frame and then drill out the peg (pillion step bar) to match?
    Snaphappy's Avatar
    Mar 2008
    ExPat in Germany
    Re: Pillion Step bar , pin step bar Joint
    Links or pics would help
    A new larger gauge clevis pin would be best (I think)
    http://www.xrv.org.uk/RD04_FICHE/rd0..._target42.html
    BobA's Avatar
    BobA is offline xRv PiMp ;-)
    Sussex Riviera
    If you have access to welding equipment, you could just carefully add weld material around the enlarged hole, then re-drill it to the correct size.
    Wingnut's Avatar
    Sep 2009
    Ireland
    Clever
  1. Another step on the road to "Oldgitism"
    By Wee Jack in forum Chatter
    Last Post: 15-04-09, 01:41 AM
  2. One step forward, and...
    By cafe650 in forum Dominator / FMX
    Last Post: 27-09-07, 07:49 PM
  3. Now step 3?
    By piguglyshandydrinker in forum Chatter
    Last Post: 20-01-06, 04:54 PM
  4. One step closer.
    By DM in forum Africa Twin
    Last Post: 10-06-04, 09:37 AM
