Results 1 to 7 of 7
Thread: Side stand switch bypass
    Jan 2005
    Thailand
    I have a quick AT question that I cannot find the answer to using search.
    I would like to disable the side stand switch like many other people. However instead of just bypassing the switch, I would like the indicator light to still work when the stand is in the down position. So in essence I would need to trace the wires up to where they perform their cut off duty, and bypass it there. Would appreciate any help.
    kennymact's Avatar
    Sep 2006
    christchurch/newzealand
    Re: Side stand switch bypass
    If you by pass it ,it won,t work!!!!!
    AlanH's Avatar
    Bristol, UK
    Leave the switch in place and short the green wire to the yellow/green. Don't touch the pink wire. That will make sure the indicator still works but the actual cutout is bypassed.
    Those should be the right colours. Any problems then report back
    Hodgo's Avatar
    Hodgo is offline Honda Adventure Rider
    Jul 2009
    Australia (Brisbane)
    Excellent, Just what I was after.
    tks
    Jan 2005
    Thailand
    Thanks AlanH !!!
    Just finished it, works perfectly. Side stand light works correctly, yet it will now start in either the up or down position. Tapping the green to green/white is correct. However on an RDO7A the third wire is a yellow black which is left alone. I pulled the side cover off, and tapped the two wires together just below the plastic plug. I just stripped the wires slightly for quarter inch in the middle, and then soldered a wire across each of them.
    Then taped it all up, looks like new again. I never use those goofy wire taps made of plastic. Easy to use, but eventually cut the wire.
    Now just need to remember to put the kickstand up when I ride off.........
    AlanH's Avatar
    Bristol, UK
    I didn't realise the RD07A had a different wire colours for the warning light. I was basing the info on the RD04.
    Top result. I might do that on my CRM too
    trophydave's Avatar
    trophydave is offline Senior Member
    Feb 2007
    Nottingham
    Sounds good.I remember my GT750 Kawasaki would go along the road coughing and farting with the sidestand light flashing even though the stand was up.
    Rust never sleeps
  1. Side-stand spring.
    By dogwheel in forum Transalp
    Last Post: 29-06-09, 10:50 PM
  2. Xr600 side stand??
    By TWIN BURNER in forum XR
    Last Post: 05-02-09, 04:52 PM
  3. Side Stand
    By Archa in forum Mechanical Advice
    Last Post: 14-07-08, 05:00 PM
  4. Side stand
    By cip in forum Africa Twin
    Last Post: 15-05-07, 03:09 PM
  5. Suicidal side stand
    By jabba in forum Varadero
    Last Post: 14-05-07, 06:48 PM
