Results 1 to 4 of 4
Thread: RD04 Questions
    siinthai is offline Junior Member
    May 2008
    Phuket, Thailand
    RD04 Questions
    a few questions gents...and ladies if there are any here...
    will a Leo Vince slip-on can for an 07 fit an 04 ?
    crash bars for 07 fit 04 ?
    Just fitted a set of Anakees....any thoughts ?
    Advice on best results for
    a) 90% bitumen 10% dirt
    b) 60% " 40% "
    Very clunky gear box especially from start...clutch cable very stiff...adjusted with 10+mm of play ?
    BobA's Avatar
    BobA is offline xRv PiMp ;-)
    Sussex Riviera
    Re: RD04 Questions
    Quote Originally Posted by siinthai View Post
    b) 60% " 40% "
    The slip-on can MAY fit, or could be adapted to fit.
    The crash bars will NOT. RD04 and RD07 have completely different frames, so mounting point will probably not align.
    Anakees are good tyres, and will get good mileages on the bitumen.
    A 60-40% tyre option is the favoured Continental TKC80 which a lot of people on the forum use. There are other options, but I haven't used any of them.
    I would start by disconnecting the clutch cable each end to check that it moves freely as the cable does wear and bind inside.
    Hope that helps
    May 2008
    Phuket, Thailand
    Re: RD04 Questions
    Cheers Bob...
    Thanks for the info
    dandragarth is offline Junior Member
    Jul 2009
    clitheroe
    Re: RD04 Questions
    I have just fitted a new clutch cable on my 04 and it is alot lighter than the old cable.
    cheers Dandragarth.
  1. Replies: 12
    Last Post: 18-09-09, 09:25 AM
  2. My AT, some questions
    By dietbrand in forum Africa Twin
    Last Post: 14-10-08, 09:59 PM
  3. questions please
    By insainwayne in forum Africa Twin
    Last Post: 29-07-08, 09:12 PM
  4. A few questions specifically for RD04 owners
    By BobA in forum Africa Twin
    Last Post: 12-10-05, 11:22 AM
  5. RD04 fuel tank questions
    By modrover in forum Africa Twin
    Last Post: 11-04-05, 08:39 PM
