Re: Fuel Tank...
Originally Posted by
siinthai
Any clues anyone..or do I just figure orange means red in my new Rd04 world ???
Both lights should come on when you turn the ignition on and then go off after a few seconds as a bulb and circuit check. I would check the wiring to the senders under the tank and make sure that there are no loose connections. Check the sender output too with a full tank and an empty tank.
There is no way you should be able to run the tank dry without the red light coming on unless something is wrong. I regularly ran my RD04 down to the red light and it was considerably more than 8km between the amber coming on and the red coming on.
