Yesterday, I start the motor normally, a minute of worm up, turn the lights on and go. Nothing uncommon, no strange noises, all perfect... After 2km, the engine starts to cough, lose power and after 100m stops. When I try to start engine, there was no enough power in battery to start the engine, but the lights and all still works. I started to pull the motor back home. On downhill tryed to start the engine, and after 10-20m of starting, it starts to work, not good, it sounds like the engine don't get enough feul, or work with one cylinder. After 200m, the engine stops again. At home, I put the new battery, and after a lot of tryouts, the engine start again, again caughing badly, the throttle response was poor and after 10-15 seconds it stops. Another tryouts was wasting of time. It was late and dark and I left the bike.
What should I try?
Is that the symptoms of the fuel pump malfunction? Clogged gasoline flow? CDI? Rectifier?
Thanks in advance!
