Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 24
Thread: Yes another choke question RD07S
    smokeyman is offline Junior Member
    Sep 2009
    Round the world Uk to Oz
    Smile Yes another choke question RD07S
    Hey there,
    ON my recently acquired AT I have choke issues, i have lubricated the cable but does not fix the challenge at stake. Im after some info on how to dismantle the plunger out of the carbi to further my investigation. In looking at the Haynes Manual they show a nut to unscrew and then you simply pull the plunger out. Not so simple, mine does not seem to have that nut to unscrew at the end where it meets the carbi. I think they show a 650.
    I realise the choke is delicate and dont wont to break anything cause it costs.
    Can anyone help me out.
    Cheers Marty
    BobA's Avatar
    BobA is offline xRv PiMp ;-)
    Sussex Riviera
    Re: Yes another choke question RD07S
    Hello Marty & welcome to the forum.
    Choke issues are sometime the bane of AT ownership.
    What you need to do is check the entire choke mechanism from the lever, down the single cable to the splitter where two cables emerge to go to each carb.
    In my experience, the splitter is the usual culprit, as it collects moisture and crud, and the grease or whatever lube the factory puts in there make it all seize up. It is possible to clean and work in fresh lube, but you do have to take your time to work it into the cables. It may be better to replace the cable!
    The next area is the springs and plungers. Again, these seize.
    The parts you need to be VERY careful with are the plastic knurled nuts/retainers which hold the choke cables and plungers into the carbs. These get brittle and break, and it'll cost you £45 atleast if you do lose or break one.
    The parts you need to look at are numbers 8 (x2) in the pic. This is where the choke cable passes into the angled tube 21, and then through the knurled nut.
    The choke cable is in this one, item number 4
    Sep 2009
    Smile Re: Yes another choke question RD07S
    Hey Bob,
    Cheers for the quick reply, I check my choke plunger out again and I dont seem to have the plastic knurled nuts/retainers as shown on No. 21. It seems to have the curved plastic piping adjoining a longish plastic nut (10 to 15mm) then another plastic part conecting the whole thing to the carbi. It is definitely different to the one you had pictured. When i try and turn the nut with a spanner it seems to move the whole plastic bit, it is in such a tricky spot to get a shifter at and i cant actually make half a turn with the spanner. So what do you reckon is the next plan of attack?
    Would you also happen to have a electronic copy of the manual with all the drawing, pics etc.
    Cheers for your help.
    Marty
    BobA's Avatar
    Sussex Riviera
    Marty
    Copyright law means electronic copies of the Honda manual cannot be distributed on the forum.
    The Tech section, up in the top right of the screen has all the fiches and parts numbers you'll need. Here is a quick link HERE
    Good Luck
    tramp's Avatar
    Feb 2009
    hampshire/Fareham
    hi smokeyman.
    on the 650 alps I just release cable at bar end nad wit hlong nosed pliers pull the long plastic shield exposing the lower cable and then spray some anticorrosive stuff [ACF50] into it and leave then spray more reattach and , voila!! choke smooth and sweat do this every spring and mid winter for trouble free use.
    As stated the water [rain] runs down the cable to lowest point [carbs] and rusts bad design but atleast it can be fixed unlike other bikes
    The small plastic nuts are a real pain to remove thats why I loosen cable.
    tramp
    Sep 2009
    Brilliant, cheers for the link.
    Ill keep trying to figure out the plunger part. Maybe i need to do it in daylight to see better.
    magwa's Avatar
    UK West Midlands
    Quote Originally Posted by smokeyman View Post
    Hey there,
    Cheers Marty
    you need to remove your petrol tank and the whole air box to get at the front and rear choke assembly
    you need little fingers to unscrew the plastic nut
    be very careful as each assembly ( as pictured in this link) costs £51.95 plus vat from mr honda
    the little ( bic biro) springs rust and the pile of rust makes the choke stick.
    The 750 ( RD07 and RD07A) should look as pictured that is unless somebody has put the wrong assembly into your bike?
    good luck
    Magwa:
    Given up Adventure Biking
    Magwa can now be found at
    There's no nut, the whole plastic choke body turning sounds right to me. Also only being able to get the spanner on it for a fraction of a turn sounds about right too. The slightest variation from keeping it straight when turning can snap the plastic part very easily, I reckon the heat makes it brittle after a few years.
    I'm so glad I just got rid of the whole thing, no choke to worry about at all these last few years.
    stageonesimmo's Avatar
    Nov 2006
    Yep same here - not had them on mine for ages and its not affected it one bit............
    Quote Originally Posted by stageonesimmo View Post
    Ya see and you're practically in the Arctic.
  1. Choke
    Last Post: 06-06-11, 11:30 AM
  2. Well it ain't the choke!
    Last Post: 13-05-09, 03:17 AM
  3. SLR choke
    Last Post: 01-10-08, 01:26 PM
  4. Choke....again
    Last Post: 13-07-08, 06:37 PM
  5. xrv 750 choke
    By jabba in forum Africa Twin
    Last Post: 12-12-06, 08:05 PM
