Results 1 to 2 of 2
Thread: 650 TA carbs on RD03 ?
    Underground's Avatar
    Underground is offline Senior Member
    Sep 2008
    French pass New Zealand
    Does anyone know if the 650 transalp carbs are compatible with an RD03 ?
    My carbs are a bit had it and Im looking for a quick cost effective fix.
    Kjell Lindberg's Avatar
    Sweden
    Re: 650 TA carbs on RD03 ?
    As far as I know, the 650 Transalp carbs is not a direct substitute for the RD03 carbs
    Transalp XL650V, 2000-:
    XRV650, RD03, 1988-89: (Keihin 32mm )
    That said, I guess everything is possible with some devine engineering.
    I think it would be better to contact a company like David Silver, http://www.davidsilverspares.co.uk/ or Wemoto, http://www.wemoto.com/
    or John Oldfield, http://www.johnoldfield.co.uk/ and investigate if there are any servicekits for your carbs.
    Perhaps the carbs from the Transalp 600, 87-88 would be more suitable?
    Check the carb bore between the two, I think most of the RD03 specific hardware could be swaped over to the TA carbs
    Transalp XL600V 1987-88 PD06 32mm CV Keihin type: VDF0A A
    Transalp XL600V 1989-96:
    Read more:
    rebuilding RD03 carbs
    RD03 carbs
    http://www.japparts.nl/index.php?mai...0a&language=en
    Check if this bike uses the same carbs:
    Honda VT750/700 Shadow
    Year 1983-1985
    If so then you can get a servicekit from here:
    http://www.motorparts.nl/index.php?m...h=79_86_93_230
    If not, then Ebay Germany, France, GB or Italy would be the place to find a better set of RD03 carbs
  1. When my Carbs are OUT, my carbs are IN!
    By darthDassie in forum Africa Twin
    Last Post: 15-11-11, 02:39 PM
  2. RD03 carbs
    By holla in forum Africa Twin
    Last Post: 22-02-09, 05:40 PM
  3. rebuilding RD03 carbs
    Last Post: 03-02-09, 10:23 PM
  4. Are my carbs on right?
    By KTiM in forum Africa Twin
    Last Post: 25-01-07, 07:20 PM
