Results 1 to 10 of 14
Thread: starting up my @
    dakarolin's Avatar
    dakarolin is offline NoooBeee
    Sep 2009
    singapore
    starting up my @
    Hi folks, newbie here.
    would like some advise from u guys.
    1st wen i bought my bike, i can always cold start it with one press of the ignition & rev will maintain till warm.
    Now, it keeps on dying and i need to maintain throttle for few secs to maintain the rev.
    Subsequent start is fine tho.
    Is it normal for old bikes?
    Should i worry? hehe.
    tramp's Avatar
    Feb 2009
    hampshire/Fareham
    Re: starting up my @
    hi,
    simple question are you using the choke to start? if not do so.
    Choke plungers probably jammed [usual thing]
    check for clean airfilter?
    what colour are plugs?
    if above all okay then you have a air leak on induction side somewhere but that should make bike run lean all time not just at start up!
    Russell
    dakarolin's Avatar
    Sep 2009
    singapore
    Plugs are new, filters are clean & just serviced my carbs lately
    I've never used my choke before, heard from some fellas its not advisable to choke when starting.
    Can enlighten me pls?
    RodYork's Avatar
    RodYork is offline Senior Member
    Jul 2009
    York
    Quote Originally Posted by dakarolin View Post
    Ask your fellas when would you use the choke- I would use it when cold or hard to start, assuming all other parts of bike are fine(as you have indicated). Just don't leave it on too long
    tramp's Avatar
    Feb 2009
    hampshire/Fareham
    hi dakaolin,
    sounds like you engine needs a bit of choke to start as already suggested, try it and if it starts okay [problem solved] but use only a bit of choke not full amount then push in before leaving.
    As we all say "honda wouldn`t have fitted it if it were`nt needed"
    I now it aint that cold in singapore but it is in the hill stations of Malaysia
    tramp
    Huib Holland's Avatar
    Huib Holland is offline Senior Member
    Jun 2009
    Holland
    Hi there,
    I always start with choke and let it run for minute. Is there a reason why this could be bad for the engine???
    Greetz
    TrevtheRev's Avatar
    TrevtheRev is offline Junior Member
    Oct 2009
    Bognor Regis
    Huib
    There's nothing wrong with using the choke to get you started, as Tramp said - it's normal, that's what it's for.
    I always have to use choke, that way it starts first time. Then when it's warming the choke goes in and off we go.
    Trev
    Jun 2009
    Holland
    That's what i thought, couldn't come up with a reason why i shouldn't...thanks
    dakarolin's Avatar
    Sep 2009
    singapore
    Thanx for the views my frens..glad i found this reliable website & hear opinions from ppl overseas as @ are quite rare in my country.
    -peace-
    grazie is offline Senior Member
    Jun 2007
    North London
    Could be fuel evaporating in the carbs making it slightly harder to start if bikes been sitting for a while.
    If I lived on the equator I'd go the choke cable removal and blanking off route that many others have done, you may even get better fuel economy.
    In Cameron Highlands you could always bump start it down a hill.
    Africa Twin RD03
  1. Non starting XR 250.
    By Pieeyedpiper in forum XR
    Last Post: 07-07-09, 10:25 PM
  2. Xr 400 starting
    By jack19 in forum XR
    Last Post: 07-06-09, 08:19 PM
  3. Starting RPM?
    By stelladragon in forum Dominator / FMX
    Last Post: 18-01-09, 01:19 AM
  4. Just starting off...
    By Ian1970 in forum I'd like to introduce myself....................
    Last Post: 07-10-08, 11:25 PM
  5. XR 400 Hot Starting
    By DaveS in forum XR
    Last Post: 12-06-07, 10:52 PM
