Results 1 to 6 of 6
Thread: 1990 AT HRC paint codes
    Farmboy's Avatar
    Farmboy is offline Senior Member
    May 2008
    In My Own World
    Just to finally put it to bed below are the following codes for the RWB HRC 1990 Africa Twins hopefully this should clear up maters for anyone not knowing the codes. The older 650 Twins have the same colours by the looks of it.
    They are Palinal codes and are as follows
    Shasta White = NH138M
    Blue Viola = A896 (the lighter blue stripe)
    Monza Red = R110
    The other colour is the dark blue which I didnt bother to get a code at present but will later
    HTH anyone looking to do any mods or respraying.
    Last edited by Farmboy; 10-11-09 at 07:53 PM. Reason: coz i almost got everyone painting kwakker green instead of Monza Red
    BobA's Avatar
    BobA is offline xRv PiMp ;-)
    Sussex Riviera
    Re: 1990 AT HRC paint codes
    I think the dark blue is BLUE SCURO A899
    http://www.xrv.org.uk/forums/africa-...our-codes.html
    Farmboy's Avatar
    May 2008
    In My Own World
    BOB,
    I reckon your spot on there, it was your original posts that gave me the headstart on the codes so thanks should go to you,
    I just wanted to confirm it for others as I have just bought the paint and tested it out on the panels.
    Chris
    BobA's Avatar
    Sussex Riviera
    Chris
    Actually I think you deserve the thanks. I notice there is a difference in our RAL codes for "Monza Red", so I would have to recommend your one as you've actually bought and tested the stuff. Mine was just a comparison using a RAL book and an RD03 panel I took into the store.
    Would "we" be spraying some new fibreglass sir??
    Regards
    Farmboy's Avatar
    May 2008
    In My Own World
    Well BOB Just ran out to the shed to check the code on the tin.
    Yours was right R110 is the correct code dont know where i got R133 from
    And yes i might be spraying up the odd bit of history
    hopefully soon to be completed
    BobA's Avatar
    Sussex Riviera
    We need to talk about the parts you had made at some point methinks!
  1. RD07a paint codes..
    By banger 115 in forum Africa Twin
    Last Post: 19-02-10, 10:37 AM
  2. Honda Paint Codes
    By max_boy in forum Varadero
    Last Post: 14-05-09, 03:50 PM
  3. TA paint codes
    By Grendel in forum Transalp
    Last Post: 01-07-08, 01:30 AM
  4. 650 engine paint color codes
    By LUNLUNZAI in forum Transalp
    Last Post: 22-03-08, 01:23 AM
  5. Honda paint codes & names
    By piguglyshandydrinker in forum Mechanical Advice
    Last Post: 24-07-07, 10:15 PM
