Results 1 to 5 of 5
Thread: Fuel indicator lights RD04 and Ideal jetting
    tatoo's Avatar
    tatoo is offline Member
    Feb 2009
    South Africa
    Hi there. I am just too lazy to read my workshop manual. Is there any one that can shortly tell me how to test the sensors in the tank without exploding it. Both my red and yellow lights switch on with the ignition, so I believe there is no problem there but neither of them light up when I run out of fuel. Straight replacement or wiring?
    Then does any one have suggestions for jet sizes, I am running a Leo Vince slipon. My air cleaner is made up of aftermarket filter foam, so I accept it breaths a little easier than normal.
    Situated at approx. 200m above sea level.
    AlanH's Avatar
    Bristol, UK
    Re: Fuel indicator lights RD04 and Ideal jetting
    Quote Originally Posted by tatoo View Post
    Test the resistance of each sensor with a multimeter at the connector on the left side of the tank. Do it with a full tank and again with an empty tank. Compare with the readings in your workshop manual.
    Ahh. Slight problem then
    will's Avatar
    will is offline Senior Member
    glos
    Had this problem on mine removed sensors and cleaned up ends and they worked fine also i left one tap off so i always had bit of fuel left
    09 Yamaha xt660z , 07 CCM 404 ds
    tatoo's Avatar
    Feb 2009
    South Africa
    Okay I will read the workshop manual, I am not really that lazy. Also reading is a lot less tiring than walking for fuel.
    tatoo's Avatar
    Feb 2009
    South Africa
    Quote Originally Posted by will View Post
    Clever, thanks will do the tap thing.
  1. Down-jetting for fuel economy
    By scarfacehugo in forum Africa Twin
    Last Post: 28-08-10, 07:43 AM
  2. Lights/horn.indicator switch assembly
    By R0vers in forum Africa Twin
    Last Post: 26-11-08, 03:05 PM
  3. Indicator on with lights!
    By Knobblywobbly in forum Africa Twin
    Last Post: 26-10-08, 08:31 PM
  4. indicator running lights
    By shnesdi in forum Transalp
    Last Post: 26-01-07, 12:20 PM
  5. RD04 - Fuel Lights ....
    Last Post: 08-10-04, 05:03 PM
